nv4500 solid truck for 3k..should i?
Old Oct 7, 2011 | 11:05 PM
CTDAC14's Avatar
Default nv4500 solid truck for 3k..should i?
Chance at buying a 01 3500 4x4 srw. For 3k the body is solid. I need the doors fenders and wanna do a 5 speed swap has dana 60 axles it is a gas motor so what would I need for the tranny to mount to my 24v. Also is this an investment I can. Sell the motor frame my build auto tranny and axles bed etc?? Also is the 01 d60 disc brakes
Old Oct 7, 2011 | 11:47 PM
dieseldude848's Avatar
is it a v10? if its a v8 im pretty sure the trans, and t-case are different/weaker, and it should have discs in the rear. i believe they started that in 2000. also the rear end is a dana 60. only the v10 and diesel came with d70's or 80's.
Old Oct 7, 2011 | 11:52 PM
CTDAC14's Avatar
its a gas thats all i know just found it on craigslist.
he did make it apoint to say it was a nv4500 trans
Old Oct 8, 2011 | 12:07 AM
empty wallet's Avatar
I wouldn't do it. You can find 12 valve 5 speeds for that price, and steal the p pump off it to boot
Old Oct 8, 2011 | 10:48 AM
yeah like i said i believe there a little different in strenght, but you said its a 3500 srw they only made 3500's in drw
Old Oct 8, 2011 | 04:18 PM
thebullet83's Avatar
you could get a 3500 srw.
Old Oct 8, 2011 | 04:34 PM
Cody Cummins's Avatar
Default Re: nv4500 solid truck for 3k..should i?
Id say hold off you can get a running cummins for that price
Sent from my PG86100 using Tapatalk
Old Oct 9, 2011 | 05:59 PM
not on a 2nd gen.
Old Oct 9, 2011 | 08:13 PM
LORDDiESEL's Avatar
not on a 2nd gen.
I believe you're correct.
Old Oct 9, 2011 | 10:59 PM
unless its a srw conversion witch i have heard of people doing, or had 1-ton leafs and coils put in. they never made a factory 3500 srw. or it might have the doors and emblems off a 3500 dually from a junk yard or somthing because orginal doors that were rotted. witch makes the most sense now that i thought about it.
doublehbar
13
Aug 9, 2015 12:35 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
