Torque Diesel Visit - Torque Diesel
!!! NEW !!! Traction Bars
Old Oct 6, 2011 | 10:25 PM
cummin_un_glued's Avatar
FormerVendor
Default !!! NEW !!! Traction Bars
here is our newest in house product
these are made from 1.750 soild aluminum and feature lazer cut and cnc bent frame and axle brackets as well as poly "ballistic joints" from ballistic fab and are threded right and left hand for easy length adjustment and are hexed on each end for a 1-1/2" wrench
all will be built after the order is placed and because they are application specific price will depend on application, the set featured are for a quad cab short bed 3rd gen but also fit a 2nd gen reg cab long bed.
sizes range from 48"-96" in aluminum mild steel and stainless steel also soild hex material or fluted round stock
also a note for drag racers the 60" bars pictured above are only around 5 lbs each for the bar alone...in fact the ballistic joints make up allmost 50% of the total weight
Old Oct 9, 2011 | 02:22 PM
DIESELKILLER's Avatar
Dustin can i get a pm on a price for these for my truck? an im guessing weld on only no bolt on? this will be for a 3rd gen quad cab short bed as well an 60"
thanks!!!
Doug
Old Oct 9, 2011 | 03:19 PM
FormerVendor
Doug,
Yes they are weld on only but the frame brackets are slightly wider then the frame so it would be possible to make them bolt on by adding a plate to the bracket. The axle brackets could be changed for a set that would replace the bottom ubolt plate.
48" - $600
60" - $650
80" - $700
96" - $750
making any of the above bolt on would add around $50
Old Oct 10, 2011 | 09:27 PM
FormerVendor
update, we put the bars on a scale tonight and they come in at 27lbs per side for the entire kit, each 60" bar alone weighs 13lbs
Old Oct 11, 2011 | 06:53 PM
Hightech_Redneck's Avatar
are the aluminum going to be able to handle the pressures? looks very good though man
Old Oct 12, 2011 | 07:03 PM
FormerVendor
Since they are solid I think so but we have not tested them on a puller yet. I know they wont bend or break it will be more about the amount of flex they have. I will be running them on ojr 2.6 truck.
Old Oct 12, 2011 | 07:11 PM
mikmaze's Avatar
sharp, any chance on bolt on units?
Old Oct 13, 2011 | 10:45 AM
FormerVendor
Yes it can be done for 50 bucks more and the bracke gussets would come fully tig welded in that case.
Old Feb 16, 2020 | 08:55 PM
Mike Wild's Avatar
Default Still available?
Attachment 40079
Attachment 40080
Attachment 40081
Attachment 40082
Are they still available?
Farmboy 2.0
For Sale
Sep 22, 2012 05:32 PM
Farmboy 2.0
For Sale
Dec 21, 2011 11:44 AM
whitelightning19
Transfer Sled Pulling
Mar 1, 2011 01:48 PM
06 DIESEL
Tire, Wheel & Suspension
Jan 25, 2009 12:04 AM
JesseRohr
Aug 6, 2007 04:25 PM
