cuts out after 3000RPMS???
Old Oct 6, 2011 | 09:42 PM
turbo2332's Avatar
Default cuts out after 3000RPMS???
will free rev only to 3500rpms and when you rev her out in low lock she cuts out like crazy. springs are way tighter than what spec calls for. ive checked them and they are in there right. truck drives good and all but when you go to get routy it just doesnt have the a$$ i think it should.
do i need more fuel? DV's? filters are new and clean
Old Oct 6, 2011 | 10:05 PM
Sudia247's Avatar
I think it has to be in the gov spring assembly, not needing more fuel. My truck has about the same mods as yours, and revs to 3500 with no problem in gear, and revs to the same without load with no problem as well, I just have never gone higher by choice.
Old Oct 6, 2011 | 10:26 PM
turbo2332's Avatar
im thinking about shimming the little spring out a little bit to see if that changes anything? and ive heard of guys going over 4000 with these springs. how tight do you have yours set?
Old Oct 6, 2011 | 10:30 PM
mysterync's Avatar
Default Re: cuts out after 3000RPMS???
Sounds like the springs are to loose
Old Oct 6, 2011 | 10:55 PM
turbo2332's Avatar
wouldnt that be nice. they are cranked so far down im afraid if i go any farther i might break one of the ears of the clicker nut thingy.
Old Oct 6, 2011 | 10:57 PM
Sudia247's Avatar
Im not sure how tight they are set, they were already installed on the pump when I bought it.
Old Oct 6, 2011 | 11:01 PM
mysterync's Avatar
If you have them that tight without adverse reactions it makes me think your spring pack if the wrong height or spring rate. Possibly a governor assembly issue outside the spring pack.
Old Oct 7, 2011 | 08:39 AM
turbo2332's Avatar
ive thought the same thing. they are peak springs installation went just fine but if you set the keeper to .050 or whatever spec is the truck wont rev passt 1500 rpms.that is why they are cranked down so far.
Old Oct 7, 2011 | 08:58 AM
93_Fummins's Avatar
Almost sounds like a spring or shim is missing... Did the springs come with a modified base to go in with them? My PacBrake 4KGSK came with a modified spring base to replace the stock base and shims. I tightened mine down to the stock stem spec and mine free revs just barely up to 4000 rpm. Is the kit maybe missing a spring during installation? I think one of the stock springs gets reused, or it did in my kit...
Old Oct 7, 2011 | 09:53 AM
turbo2332's Avatar
ya they came wwith new bases there are 3 stock shims that dont get reused the largest spring is the idle spring and it gets reused. im stumpped?
