NEED HELP with ac compressor
Old Oct 6, 2011 | 06:51 PM
flmikej's Avatar
Default NEED HELP with ac compressor
I have a 03 2500 and when my ac compressor kicks on it makes a loud clicking noise (like a baseball card in a bike spoke) it doesnt stop untill i turn off the ac.I replaced the water pump about 5 months ago,about 2 months after the water pump i heard a howling noise and replaced the belt tensioner and belt and the howling went away.But about two weeks after i did the tensioner and belt the clicking noise started so I returned the tensioner and installed another one and same problem.My ac still blows cold and still has good pressures out of the compressor.Could the noise stated above be the tensioner (the part i installed was aftermarket) or can the compressor make noise and still be fully functional.Thanks in advance for the help
Old Oct 6, 2011 | 09:22 PM
Whit's Avatar
Site Mascot
process of elimination...........turn yer ac comp off and try it again
Old Oct 6, 2011 | 10:07 PM
mykaos's Avatar
A/C comp can function and be noisy
Old Oct 6, 2011 | 10:49 PM
flmikej's Avatar
Question
The truck drives and runs fine. If you watch the belt and tensioner with the AC off it looks normal ,but as soon as the compressor kicks on it starts making a slapping or clicking noise and the belt and tensioner start jumping around.
Old Oct 7, 2011 | 08:08 AM
Whit's Avatar
Site Mascot
I would pull the belt and inspect the compressor....it may be going out, also I believe they sell a belt to bypass the compressor......since its winter and all this would give you some time
Old Oct 7, 2011 | 11:36 AM
flmikej's Avatar
On the 2003 can you replace just the clutch on the compressor?
Maclain Marsh
Jul 13, 2015 06:23 PM
petew
Jun 26, 2015 05:58 PM
Air Lift Company
AirLift
11
May 27, 2015 04:38 AM
chomitmy
Dec 10, 2014 09:54 AM
carid
Diesel Bombers Sponsors
Dec 4, 2014 05:06 AM
