Parting out 1998 12 valve engine.
Old Oct 6, 2011 | 05:43 PM
Mark Nixon's Avatar
Default Parting out 1998 12 valve engine.
I have a 1998 12 valve that I'm looking to part out.
Picked this up thinking that MAYBE I'd use it, then found out that is has a 53 block.
It has a spun main on number one, the crank doesn't look hurt and the bearing didn't appear to damage the block, but I was told there was "a noise" in the engine.
It is a complete engine with all accessories, was a 5 speed 215 horse engine that had @ 250,000 miles on it.
I would part it as follows:
Complete P-7100 Conversion, case, cover, 215 horse '913 P-7100 pump, linkages, mounting supports, lines, gear, $1200.
Cylinder head, no injectors, no manifold or intake, INCLUDES rockers, $350.
Oil pan and pick-up, no nasty dents, $125.
Exhaust manifold, $65.
Bare '53 block $$?? NOT CRACKED (yet) Scrap metal?
Front accessories, $20-up inquire.
HX35W Turbo, feels a little loose, no wheel contact, should run fine, $150.
I'd also entertain offers as a complete unit!
Reply here, PM or call 402-780-5127.
Old Oct 11, 2011 | 11:57 PM
gd1996's Avatar
Still got the conversion?
Old Oct 11, 2011 | 11:59 PM
Mark Nixon's Avatar
Yes I do.
Mark.
Old Oct 12, 2011 | 12:07 AM
gd1996's Avatar
I sent ya a pm... maybe you'll remember me from back in the day.
Old Oct 13, 2011 | 11:24 AM
Mark Nixon's Avatar
Finished blowing it all apart yesterday, adding to the list:
1998 53 Block (STORM), ZERO CRACKS, with 250,000 miles, if it isn't cracked by now, it probably won't, will maintain standard bore, $150.
Crank, damaged on number 5, should go .010-.010 okay, $100.
Cylinder head, 1 tiny crack at #4 between valve seats, no others found, $200.
6 MEXICO Rods, #5 has bearing material on it, would definitely re-size, $120.
Oil pan with strainer, needs cleaned, $125.
Stock '94-'98 12 valve engine mounts, $60.
Also, I still have the complete injection pump conversion, as well.
Mark.
Old Oct 13, 2011 | 01:31 PM
olblue02's Avatar
Deal on the pan and engine mounts
Old Oct 13, 2011 | 02:20 PM
Mark Nixon's Avatar
PM me on them.
I'll treat you good on the shipping, too.
Mark.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Alaskabound
Aug 27, 2015 06:42 AM
hoeky22
For Sale
Mar 15, 2015 08:35 PM
LTreis702
Feb 14, 2015 12:52 PM
