47RH wont shift into forward gears
Old Oct 5, 2011 | 09:08 AM
bwskweeker's Avatar
Default 47RH wont shift into forward gears
My boss has a 96 cummins with the 47RH tranny and it will drop right into reverse but takes forever to shift into the forward gears. The colder it is, the longer it takes. Brand new valve body and fluid leve is fine. any ideas? appreciate the help
Old Oct 5, 2011 | 11:43 PM
usmc0311's Avatar
I dont know anything about auto's but im just gonna throw something out there and maybe it'll help. Have you adjusted the throttle cable?
Old Oct 6, 2011 | 09:33 PM
turbo2332's Avatar
you have a 47RE the rh was only from 94-95. was the truck doing this prior to the new valve body? i just had a similar issue with my 95 ended up being a messed up VB. and its not the TV cable that just messes with when it shifts. you can adjust the 2nd gear band from the driver side of the tranny 3/4 nut with a i think 5/16 center. crack the nut and finger tighten the bolt till you feel it bottom out on the band then back it off 3/4 of a turn and lock it down.
Old Oct 7, 2011 | 12:15 AM
bwskweeker's Avatar
Oh ok haha i dont know jack about auto trannys. Honestly Im not sure if it was doing it before the new VB ill have to ask. Ill definitely let him know about that and see of it works. thank ya
AKDodge
May 14, 2015 12:52 PM
Bigbird31
Apr 23, 2015 12:37 PM
davidthomas
Mar 24, 2015 12:41 AM
rabidrabbit
Mar 6, 2015 03:47 AM
Nov 5, 2014 11:10 AM
