UGH! My truck is doing it again!
Old Oct 5, 2011 | 04:06 AM
Youngblood's Avatar
Default UGH! My truck is doing it again!
Ok, so back in june my truck started to act up. I would be going down the road and a bunch of warning lights would come on, the truck would start dining, and the speedo and tach would all drop to zero, the motor runs fine while this happens so it HAS to be electrical. But anyways I disconnected the batteries and let it sit overnight then in the morning reconnected them, solved the problem, never happened again. Until now, went out tonight to start my truck and it did it aagin. So i shut the truck off and fired her back up, no problems. so went into town and was on the highway on my way back home and it started doing it at 70mph, I'm including a pic i took of my gauge cluster while it was happening. And to add, it would do it in like 2 second increments. the truck would ding, the dash would act up, then back to normal, ding again, and the dash would act up and so on. it did it about 6 times before stopping. I'm to the point i am frustrated beyond belief and frankly getting tired of this. Dealer can't figure it out and I'm out of ideas.
Picture should be attached.
Attached Thumbnails UGH! My truck is doing it again!-2011-10-04-23.13.54.jpg
Old Oct 5, 2011 | 08:43 AM
dangerous1965's Avatar
Clean your battery connections
Old Oct 5, 2011 | 11:29 AM
NadirPoint's Avatar
TIPM (Total Integrated Power Module)
Just a WAG (Wild-Assed Guess)
Old Oct 9, 2011 | 03:30 PM
Youngblood's Avatar
Well i cleaned the battery terminals and cable connections, and it now only does it like twice when i first start the truck up. Anyone else have any ideas?
Old Oct 10, 2011 | 02:11 PM
kylemckay's Avatar
does the dash say (no bus) sometimes when this happens? sounds like the j1850 is shorting to ground
Old Oct 13, 2011 | 02:55 AM
Youngblood's Avatar
no it doesn't ever say no bus
Old Oct 13, 2011 | 07:43 PM
Red Mega's Avatar
Codes?
Old Oct 14, 2011 | 04:07 AM
Youngblood's Avatar
Originally Posted by Red Mega
Codes?
None
Old Oct 16, 2011 | 06:44 PM
dcpowell17's Avatar
I think it is a bus issue as well. The bus signal wire is in the itigrated power module. It is a .5 volt reference signal for gauges, a/c module, overhead console. Mine had pulled slightly loose and was killing gauges and my a/c module. Examine your integrated power module very closely from the under side. Make sure they are all making good connections.
Old Oct 24, 2011 | 02:26 PM
Youngblood's Avatar
Where is the module located?
doublehbar
13
Aug 9, 2015 12:35 AM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
