low fuel pressure. spikes then drops.
Old Oct 5, 2011 | 01:38 AM
flatbedr's Avatar
Default low fuel pressure. spikes then drops.
98 12 valve. i have a in cab fuel pressure gauge. electric sender. at idel its exposed to b between 17-23 psi at 2500 rpm no load its exposed to b 25-30. im at 10-14 at idel an 20-24psi at 2500 rpm no load. when driving its usually like 10 psi if i let off the throttle an just cruise it goes to 20. then i get back into it an it will spike up to 40 then to back to 20 then up to 30 then to 10 again an stay there till i change throttle position. what im really worried about is running the truck lean.- low fuel pressure. iv changed the filter an i have a tork tek overflow valve. neither changed anything. my buddies tell me im paranoid, but i swear its not the same as it was. this truck is how i make money an my daily driver. i take very good care of it an cant afford to be broken down with a trailer in tow. im afraid my pump is going out. any help from experienced cummins mechanics would b gratefully appreciated. thank you
Old Oct 5, 2011 | 11:46 PM
usmc0311's Avatar
Do you have a snubber and a resistor (spelling) To check from the gauge spiking? and also do you still have the stock lift pump?
Old Oct 6, 2011 | 01:12 AM
flatbedr's Avatar
snubber yes resistor no. but it is fused. no relay either. its the stock pump as far as i know. truck only has 156,000. an it was babied before i got it. my mane concern is the low fuel pressure today at a stop light it was at 4 psi. but it runs super strong. towed 7k on my trailer today 70mph the whole way. then other times it feels a little dogish. im paranoid
Old Oct 7, 2011 | 09:10 PM
usmc0311's Avatar
You do need that resistor. So it can hold a steady pressure. But im not to familiar with the stock fp but what can help is get a hanes book for the truck and ill help you.
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
vfizzano
17
Oct 9, 2014 02:26 PM
