Trailer brake controller
Old Oct 4, 2011 | 11:23 PM
cfarley0210's Avatar
Default Trailer brake controller
Two of our work trucks have the same problem randomly the dash will show a code for the trailer controller problem. And when your towing and it does it you loose your brakes for the trailer has anyone else ran into this? If so whats the fix? Its scary droppin down i hill with heavy equipment on the back without trailer brakes
Old Oct 5, 2011 | 07:44 AM
Mdub707's Avatar
Typically when I see this, it's an issue on the trailer, not the truck. Are you using the same trailer when these two different trucks have this issue?
Old Oct 7, 2011 | 10:51 PM
We use lots of trailers and it does it with them all. It flashes the code all day without the trailer even hooked up. Just randomly it said tbs fault
Different trucks have no problems with the trailers at all
Last edited by cfarley0210; Oct 7, 2011 at 10:51 PM. Reason: Automerged Doublepost
Old Oct 8, 2011 | 09:00 AM
Mdub707's Avatar
Read here...
Seems like you need to check your #12 fuse...
TBC Fault code?? - Ford Powerstroke Diesel Forum
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
steed
Basement Enterprises
Apr 7, 2015 04:07 PM
Diesel_Daddy6.0
Dec 2, 2014 08:53 PM
yams
Nov 29, 2014 09:25 PM
