6.0 exhaust valve failure
Old Oct 4, 2011 | 11:16 PM
Island Diesel's Avatar
Default 6.0 exhaust valve failure
Has anyone had an exhaust valve failure. I have a truck that snapped an exhaust valve. The stem is still in the head and retained to the valve spring. The customer had just got the truck back from Ford after a high psi pump change. It lasted 400 miles and lost the valve. The truck is stock except for a 5 inch exhaust.
Old Oct 5, 2011 | 07:43 AM
Mdub707's Avatar
I've seen it once, but it was from someone neglecting to fix blown headgaskets. They kept pushing coolant and they were adding tap water... it leaked into the cylinders so much it corroded the valves into the valve guides and they started sticking... next time he went to start it up, piston smacked valve and broke it off. Destroyed the whole cylinder.
It's really not that common though if that's what you're asking. I can't really see the HPOP being changed effecting a valve either...
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
behrendt1061
Dec 4, 2014 05:49 PM
