only idling
Old Oct 4, 2011 | 03:52 PM
joeycad1's Avatar
Default only idling
00 wouldn't crank last nite,barely would this morning changed lift pump and it idles fine, but runs rough with any acceleration and will not hit 11 on the tachometer will hit 30 mph if I shift up to 5th on flat land with no pedal. Any suggestions ?
Old Oct 4, 2011 | 04:07 PM
empty wallet's Avatar
fuel pressure? codes? did you try bleeding the lines out?
Old Oct 4, 2011 | 08:53 PM
joeycad1's Avatar
went about 8 miles at idle tach and 30 mph, came back to check fuel pressure and it wouldn't start back up... pressures up over 25 when pump cycles. just got code reader and had a 1688 and 1699 along with a slew of p0### codes. tries to crank but won't keep running
Old Oct 4, 2011 | 09:31 PM
1688 is vp44 related, I know that much. give us the rest of the codes you're seeing. 25psi is a bit high for my liking, that means you could see surges of 27-28psi and that will destroy the pump.
Old Oct 4, 2011 | 09:48 PM
joeycad1's Avatar
let it cool off and will crank and idle again...cleared codes and now only two coming up. P0235 and P0252.. and 18psi when running
Old Oct 4, 2011 | 10:15 PM
Neither of these codes exist according to my go-to code sheet... are you sure about those? But even if you cleared the 1688, that's mechanical pump failure code, you can't just clear that one. It will come back, and that would also explain your hard starting issue (edit: WHEN WARM). My friend, you need a vp44.
Old Oct 5, 2011 | 11:50 AM
txbowhunter28's Avatar
Default Re: only idling
VP44 for sure. Mine did the exact same thing when the pump went out.
98suburbandiesel6.5l
Jul 25, 2015 03:25 PM
