99 5.9 starter problems
Old Oct 4, 2011 | 02:25 PM
txbowhunter28's Avatar
Default 99 5.9 starter problems
I just finished replacing the starter contacts and plunger with the kit from Geno's Garage due to my starter only clicking when turning the key to crank the engine. Now when I turn the key to on, before even trying to crank the engine, I hear a strange noise (sounds like starter motor spinning without engaging with flywheel). It only lasts about a second, and when you turn the key the engine cranks and runs normally. Has anyone else had this issue, or know what would've caused this?
Old Oct 4, 2011 | 02:33 PM
aguilar_15's Avatar
Your lift pump makes this kind of noise when its drawin fuel fuel from the tank. Now if it is your starter wheel spinning, you might've blown the solenoid.
Old Oct 4, 2011 | 02:37 PM
Default Re: 99 5.9 starter problems
It's much louder than the lift pump, and the starter still functions normally.....cranks the engine as normal.
Old Oct 4, 2011 | 03:07 PM
aguilar_15's Avatar
Hmm no idea man
Old Oct 4, 2011 | 03:38 PM
EggosBrother's Avatar
I have the new contacts and plunger sitting in the garage, have had them for 2 weeks just been putting off the swapping them out. How hard is it to get to the top bolt on the starter to take it out?
Old Oct 5, 2011 | 11:55 AM
It was simple. 10mm 12pt socket with a 10" extension will get the top bolt out. I finished the entire job, removed starter, replaced contacts and plunger, and reinstalled starter in about half an hour. Strange enough, the odd sound I started this thread about quit about the 5th time I started the truck and hasn't done it since.
Old Oct 5, 2011 | 12:13 PM
sounds easy enough, might pop that dude off of there tonight then.
Well thats a plus, just hope it doesnt come back or wind up being a problem down the road.
Old Oct 5, 2011 | 10:14 PM
RanchhandTCR's Avatar
Starter solonoids are extreamly easy, Ive done it a couple of times for my tractors and buddies trucks.
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
ronstop
Feb 26, 2015 09:48 AM
james2562
Feb 5, 2015 09:05 PM
nevadagramm
Oct 17, 2014 07:59 PM
