Power from stock turbo
Old Oct 3, 2011 | 08:15 PM
CumminsKid6's Avatar
Default Power from stock turbo
How much power do u think u could possibly be mad on a stock turbo with no injectables. Just curious
Old Oct 4, 2011 | 08:49 AM
93_Fummins's Avatar
Just enough to make it explode...
Old Oct 4, 2011 | 07:10 PM
monster12valve's Avatar
reliable power?
Old Oct 4, 2011 | 08:15 PM
seandonato73's Avatar
prolly around 300ish but youll have some high egts... get the upgrade wheel and youll be good for a little more hp
Old Oct 4, 2011 | 09:32 PM
Well I was just curious to how far u can push one. My dad 98.5 cummins with built trans 125 sticks and a adrenaline will push and has for the past 2 years been pushing 50 lbs of boost. Now I know any after like 38 to 40 is getting into hot useable air. was just trying to see what power numbers have been made with the stocker.
Old Oct 4, 2011 | 09:58 PM
aguilar_15's Avatar
I'm pretty sure the 98.5 is 24 valve, different set up so different tolerance for hp. You can make impressive numbers with stockers but they'll be on the edge of exploding. Take it easy til you can afford a good charger cause it you blow yours now, you runa very big risk of blowing compressor shrapnel through the engine and blowing it.
Also, you might want to check the head on your dads rig, 50lbs is too much for a HX35, WAY TOO MUCH! Head'll lift up, compressor wheel'll fly off, blown valve springs... so much can go wrong with that much boost.
Old Oct 5, 2011 | 08:39 AM
The only thing outta wack on my dads truck is just a small coolant leak from the water jacket to out side the head
Old Oct 12, 2011 | 10:31 PM
just wait the head gasket will be close to follow
thats what my first gen did leak coolant then two months later towing my f150 to go fourwheeling there went the head gasket....
Last edited by seandonato73; Oct 12, 2011 at 10:31 PM. Reason: Automerged Doublepost
Old Oct 23, 2011 | 12:58 PM
12valvetater's Avatar
Blown valve springs? Oh my, never heard that one before. As far as the question goes there have been the few who have knocked in the mid to upper 400 region.
Brclouse
Nov 18, 2015 08:44 AM
RatsMC
May 4, 2015 05:25 PM
GreenDieselF
Oct 20, 2014 02:05 PM
