Airdog 100 + FP Gauge
Old Oct 3, 2011 | 02:38 PM
EggosBrother's Avatar
Default Airdog 100 + FP Gauge
After searching for the past hour i have not found a post that makes it clear on the best way to install the FP gauge. The seller has offered the banjo bolt with the package but, my banjo bolt at the VP44 was removed with the Airdog install. So my questions are.....
1. What fitting is needed to tie right into the port on the Airdog
2. After reading, the majority opinion is get FP closer to VP44, whats the best setup this way?
I would just like to have this figured out before they come in the mail so i can install asap.
Old Oct 3, 2011 | 02:52 PM
Default Re: Airdog 100 + FP Gauge
Get a 90 degree tapped fitting from Vulcan Performance.
Luke
Old Oct 3, 2011 | 06:13 PM
aguilar_15's Avatar
Hate to steal your thread bud but LUKE I need a 90* fitting and a draw straw from you. Can you shoot me a pm? Thanks man.
Old Oct 3, 2011 | 08:43 PM
turbo20psi's Avatar
Fitting...This is for 1/2 line.
Tapped 90 degree 08 fuel pressure access fitting
This one is for 3/8 line.
Push on 90 Degree 06 JIC fitting tapped
Old Oct 4, 2011 | 08:25 AM
I found that fitting on there but, do i just cut my supply line and clamp to that fitting? Is there a tapped 90* out there with a 1/2 female instead of the push-on so i can still use the lock fitting that came on the end of the fuel line from air dog? (SAE J2044)
huntman7
Sep 4, 2015 04:49 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
Tyler Schafer
11
Oct 23, 2014 11:01 PM
