Heater core questions??
Old Oct 3, 2011 | 06:49 PM
Billy D's Avatar
Default Heater core questions??
Ok, here goes... I thought my blower motor was going south so I got one. Upon removal I noticed a bunch of mud(pretty much) in my heater box. I just got this truck about 4 months ago, a/c worked great, and heat also(as best as I could see @ 80 degrees) am I gona have another go with another heater core? If so, is it as bad as my 1st gen was?? This is crap, and I just sold my 1st gen Sat, so I got no other ride Thanks for any info
Is there a thread about a heater core install, , I'm gona need it fer in the morning
Hmmm, only videos I see on utube are for 98-up. Is it the same process for the 95?? I hate HC's
Does this HC slip down or is it like my 1st gen, my box is packed with mud, am I going to be able to remove this as well Am I thinkn too much, F'n HC's:arg h:
Old Oct 3, 2011 | 07:19 PM
monster12valve's Avatar
should be same as 98 and up
Old Oct 7, 2011 | 12:56 PM
Billy D's Avatar
Is there any booby traps I might encounter, or is the job perty much straight foward. Any help is always appreciated.
Old Oct 10, 2011 | 04:21 PM
1AMatt's Avatar
Site Sponsor - 1aauto
I have never personally done one... The whole dash has to come out I believe. Been told its fairly easy just time consuming
Old Oct 10, 2011 | 04:51 PM
Sudia247's Avatar
Yes just time consuming. Removing the tubes from the heater core in the engine bay are real hard, I just cut mine, and replace them, saves a hassle. The dash has a row of bolts at the top under the windshield, and one on each side on the dash, behind the kicker panel. those will let the dash rotate forward when they are loose. Drop the steering column, remove the airbag unit under the center of the dash and remove the tcase or tranny shifter to made things easier. You can rotate it out and pull off just the passenger side, most ppl use a strap from the dash to the upper grab handle. Then you got I think 4 screws on the firewall that hold the plastic unit the the firewall. The heater core is in there, and lifts out from the top. You can also change out the AC evaporator while you're there, thats on the underside of the plastic unit. Hope it goes smooth!!
94_12v
Mar 21, 2015 10:11 PM
ramrunner01
Mar 19, 2015 11:03 PM
94_12v
Feb 11, 2015 11:38 PM
jkidd
Diesel Auto Power
Dec 9, 2014 12:16 PM
crazycooter
Nov 14, 2014 09:06 AM
