Greasable lower ball joints
Old Oct 3, 2011 | 11:15 AM
01trailerpuller's Avatar
Question Greasable lower ball joints
It is that time again, I need to do my ball joints. I am looking for a set of lower GREASABLE ball joints. I have seen them so I know they exsist. If anyone can point me in the right direction that would be great.
Old Oct 3, 2011 | 06:02 PM
1slow24's Avatar
i got a set of moogs thorough advanced.. go online and look they usually have deals.. i got 20% off and a 50 store credit card worked out great
Old Oct 3, 2011 | 08:05 PM
turbo20psi's Avatar
Dodge Front Axle & Steering
Ball joints.
Old Oct 4, 2011 | 12:25 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Moogs makes a great chassis part, and they are greasable!
Old Oct 5, 2011 | 10:12 AM
Cody Cummins's Avatar
Default Re: Greasable lower ball joints
Moogs here, i gotta replace one of my moogs real soon
Sent from my PG86100 using Tapatalk
Old Oct 6, 2011 | 02:30 PM
1AMatt's Avatar
Good thing they are lifetime warranty
Old Oct 6, 2011 | 07:30 PM
turbo20psi's Avatar
Ball Joint failures on 2000-2002 Ram Trucks is a reoccurring problem that will probably plague these trucks for their entire life due to the size of the Ball Joints and the steering geometry of the 2000-2002 Dana 60 Front axle.
The Upper and Lower Ball Joints on these axles are at different angles, in other words the vertical axis of the Upper and Lower Ball Joints are neither in-line or parallel to each other. To compensate for the different arcs of each Ball Joint during turns, the modest sized, straight shank, .855" diameter stud of the greaseable Upper Ball Joint is vertically floating in a plastic sleeve. Consequently, the Upper Ball Joint does not support any weight, it merely keeps the knuckle in place. On these axles, the Upper Ball Joint is not really a Ball Joint at all, instead it is a floating King Pin that is smaller in diameter then King Pins found on 1966-1981 Ford F100 4x2 1/2 ton trucks and light 3/4 ton trucks with GVW's of 4,700 lbs-6,900 lbs.
The non-greaseable Lower Ball Joint is load bearing, in fact, the two Lower Ball Joints carry 100% of the front axle weight on your 2000-2002 Dodge Ram 2500 or 3500 truck. Dimensionally, the outside diameter of the Lower Ball Joint is only 3.5% larger than the Ball Joints used on 1972-1986 Jeep CJ's (and other light-duty models of that era) which has somewhere between 1/4 and 1/3 of the front axle weight of the Dodge Ram, plus both the Upper and Lower Ball Joints on the CJ are load bearing. In addition, the Ball Joints used on older models like the Jeep CJ and 1994-1999 Dodge Ram 2500 and 3500* shared the same vertical center line axis and were pre-loaded to compensate for wear. With the 2000-2002 front axle steering geometry using differing Ball Joint angles, no preload is possible, therefore, any wear means loose Ball Joints.
Yes, lack of lubrication with the non-greaseable factory lower Ball Joints can be a factor; however, very few of the failed lower Ball Joints we cut apart are suffering from a lack of lubrication. Replacement Ball Joints in both greaseable and non-greaseable versions are available from us, plus there are even offset upper Ball Joints out there (which in my experience is both short-lived and of limited use). Installing Greaseable Ball Joints and regularly greasing them may provide longer service life, but with the 2000-2002 axle, chances are you will still need to replace the Ball Joints every three to five years. One would not mind the relatively short Ball Joint life so much if these trucks steered better than previous models, were not subject to "Death Wobble", or had longer tire life.
Old Oct 6, 2011 | 07:37 PM
3 to 5 years would be great compaired to my 2-2 1/2 years that I have been getting.
Old Oct 18, 2011 | 10:11 AM
1AMatt's Avatar
Good rule of thumb I use is ball joints every 2 years, tie rods every 3 years Sad but true
wildbill
Oct 2, 2015 01:56 AM
LawdawgSHPD
Aug 21, 2015 06:23 PM
oznation
May 26, 2015 09:23 AM
nickpro902
Mar 14, 2015 08:46 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
