Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
coolant leak
Old Oct 1, 2011 | 03:43 PM
siesel40's Avatar
Default coolant leak
2004.5 LLy the o-ring leaks under the thermostat housing on the tube between stat and water pump. Does anyone know the easiest way to remove the tube?
Old Nov 23, 2011 | 06:58 AM
cbsmoraine's Avatar
I promise there is no easy way to do it. I had the same problem, tore the front end of my truck apart 3 seperate times to try and fix the problem. found on the 3rd time the block was cracked where the pump mounts and the loser that owned it before me, temp fixed it with JB weld, oddly enough it held for nearly a year before it gave way, but. i promise if you do it your self (make sure you have EVERY tool u need and might need) the job WILL take every bit of 3 to 6 hours. my first time was 6, i got progressivly better at it, LOL
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
Mike0885
Feb 28, 2015 03:16 PM
merdth6
Nov 20, 2014 08:01 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
