stuck in 2nd gear
Old Sep 30, 2011 | 01:13 PM
bps7576's Avatar
Default stuck in 2nd gear
i have a '99 3500- 5.9l cummins- 107,000 miles. the other day i was leaving the driveway and the truck shifted up to second and wouldn't go any higher (max 20mph). I tried going down the road, increasing the rpm's and lowering it, but the tranny wouldn't shift. I've been looking around and asking around and what i hear is it might by the transmission control soleniod. does that sound right? or would it be the control sensor? any help would be appreciated.
Old Sep 30, 2011 | 10:23 PM
turbo20psi's Avatar
Its the Governor Pressure Solenoid maybe. You can take it to a transmission shop and have them do a read on the trans.
Here is a kit that works well. Dodge Heavy Duty Master Solenoid Kit
Old Oct 3, 2011 | 05:52 PM
bps7576's Avatar
thanks... I ended up replacing the Control solenoid which didn't do the trick at first. I needed to reset the pcm, then the truck would shift properly.
6.2Lturbo
Chevy/GMC Duramax 01-04 LB7
Aug 15, 2015 01:25 PM
Daniel Leipart
Jun 28, 2015 02:42 PM
Hotrodd_67
Jun 22, 2015 09:50 PM
aoutlaw95
Mar 3, 2015 09:02 PM
rtbcoop
Nov 29, 2014 11:33 PM
