FICM PROBLEMS
Old Sep 29, 2011 | 11:50 PM
powerstrokin2004's Avatar
Default FICM PROBLEMS
2 weeks ago ficm went out on my 04 put a new one on and this morning wouldnt start out of no where checked fuses and all checked icp and voltage on ficm check for fuel and everything was good but no start any more advice
Old Sep 30, 2011 | 08:04 AM
Mdub707's Avatar
Is it turning over and just not firing? Any smoke coming out the exhaust? If so, what color? If not, then it's a good chance there's a bad connection at the FICM, try pushing the plugs in all the way under the FICM. What did you do with the old FICM? Did you test the voltage on this new one?
Old Sep 30, 2011 | 08:23 AM
Already checked voltage and plugs and no smoke yes its turning over just not firing
I still have the old one think I will get it fixed for back up
Last edited by powerstrokin2004; Sep 30, 2011 at 08:23 AM. Reason: Automerged Doublepost
Old Sep 30, 2011 | 09:20 AM
Mdub707's Avatar
I can fix them FYI.
Did you test the new FICM since the no start issue? Does it have 48V? No smoke means the injectors are not firing, my guess is it's just a loose connection somewhere, and since the FICM was the last thing replaced I'd be checking all of that over. If that's all tight, gotta start working down the line here...
Old Sep 30, 2011 | 09:55 AM
Well tested it again had 48 volts took it off and plugged back up to make sue it was connected good still nothing by the way what u charge to fix them would like to get my old one fixed for back up
Possible icp?
Last edited by powerstrokin2004; Sep 30, 2011 at 09:55 AM. Reason: Automerged Doublepost
Old Sep 30, 2011 | 11:52 AM
Mdub707's Avatar
Could be ICP. Unplug it and try restarting it.
Did you test the FICM with key on engine off, then cranking? It should be tested KOEO, cranking, and running.
I'll PM you.
Old Sep 30, 2011 | 02:45 PM
bobfbigman's Avatar
you said it is a new FICm// did you get it programmed before you installed it? it won't work unless that has been done. They do not come programmed.
Old Sep 30, 2011 | 03:12 PM
Mdub707's Avatar
Can't believe I didn't even think about it. Good call Bob.
Bloom12valve
Oct 9, 2015 03:40 PM
Brody Olson
Chevy/GMC Duramax 06-07 LBZ
Sep 12, 2015 11:01 PM
DODGEARMYGUY
Mar 3, 2015 11:40 AM
makuloco2000
Feb 15, 2015 02:31 PM
JRB1960
Dec 1, 2014 09:24 PM
