Piston help
3911400 piston is a good one.
you can also go with the lower compression piston as well, cant remeber the number for all of them.
make sure you get premium rings.
you can go here
https://www.dieselbombers.com/1st-ge...king-idle.html
it shows stock pistons and then the 3911400 piston.
you can go here
it is doing the correct way of what everone is putting a 0.020 oversized gasket on.
it will allow more air to be forced in,(really helps in larger turbos or compound set ups) if you go really low, your engine will have a hard time to start in cold weather.
