BIG PROBLEMS overheat
Old Sep 28, 2011 | 07:11 PM
mysterync's Avatar
Default Re: BIG PROBLEMS overheat
Is the bypass hose hooked up? Any exhaust gases in coolant? How did you eliminate the air from the system?
Old Sep 28, 2011 | 07:20 PM
blowinsmoke12v's Avatar
Default BIG PROBLEMS overheat
got a new head installed new water pump new thermostat got the radiator flushed and new temp sensor...and i drove it today after all together didnt even make it five miles without it gettin to almost 220 help me i have so much money involved and no clue what it could be now
Old Sep 28, 2011 | 07:59 PM
i dont think i really know how to bleed the system i just opened the cap for a little bit and i wasnt 100% on which way and what o rings to use when installing the thermostat i was confused for a little bit on that
like the direction and weep holes in it im just tired of tearing this thing down
Old Sep 28, 2011 | 08:17 PM
Billy D's Avatar
Seems silly, but I had to jack the front end of my truck up with the cap off and let it run fer a few, it worked for me. I did have my weap hole on top too though. Hope that helped
Old Sep 28, 2011 | 09:36 PM
CumminsKid6's Avatar
I know when ur getting the air outta ur coolant system ur radiator cap needs to be the highest point. Because hair travels up in a enclosed area. So if need like Billy d said if u need to jack up the passenger front tire up high let run to open the thermostat and keep an eye on fluid and fill as need. Also for me sometimes helps to pump (squeeze) upper radiator hose. And just pour coolant to her. Hope that helps. Anyone feel free to chime in with more tips or tricks. Lol
Old Sep 29, 2011 | 05:06 PM
GUYS!!! i had the thermostat in backwards ahaha im an idiot i was so precausious i overlooked the little stuff i feel like an idiot but for bleeding out well see how that goes thanks guys a bunch!
Old Sep 29, 2011 | 06:04 PM
H.R.D's Avatar
Only way to learn sometimes my friend is to F@$K up and then figure out your F#$K up. Glad you got it figured out.
Old Sep 29, 2011 | 08:03 PM
Billy D's Avatar
Old Oct 3, 2011 | 01:02 PM
now it doesnt overheat but still running above 190??? i dont see it pop open and seesaw like it used too wtf cant win i swear
Old Oct 3, 2011 | 01:55 PM
daveO's Avatar
I think they redesigned they thermostat so that it doesn't swing like it used to. I would say that as long as it's not getting above where it's at, you should be fine.
