ATF oil in my fuel tank ??
Old Sep 28, 2011 | 08:17 AM
zx97021's Avatar
Default ATF oil in my fuel tank ??
I have 2005 excurison 6.0 . I was told I could put ATF oil in my fuel tank. If so how many oz. per gallon do I use ?
Old Sep 28, 2011 | 11:28 AM
Mdub707's Avatar
You can also put sand, sugar, cement mix, cake mix, whatever you want. Doesn't mean it's a good idea.
Old Sep 29, 2011 | 10:08 AM
zx97021's Avatar
ok so you dont think it should be done
Old Sep 29, 2011 | 10:38 AM
Mdub707's Avatar
Me personally... I wouldn't run it, but I wont say you shouldn't because frankly I just haven't done enough research. I know there are guys running WMO (waste motor oil) too without issues. To me, it seems silly to take a fluid that has been used for lubrication and surely has some sort of metal particles in it, and then run it in my fuel system. I'm sure it could be done. I use WVO (waste vegetable oil) in my truck, but I use a proper system and filter really well, so I'm not against alt fuels, just some of them out there scare me. Mine is a completely secondary fuel system though.
Before you do anything, price out the fuel system for a 6.0, then think hard about what you put in the tank.
Old Sep 29, 2011 | 04:06 PM
billiard's Avatar
From what I've heard from a few older car guys is that it used to be a good thing to do but not so much anymore because of a difference in the chemical breakdown of the new formula of atf. Now its made more so it doesn't break down under heat, I've heard you might as well use 2 stroke oil. This is all only what I've heard so I cannot be sure its true
Old Sep 29, 2011 | 04:40 PM
BACONBITSFORU's Avatar
Only Ashless 2 cycle for boat motors should be used.
Old Sep 30, 2011 | 07:57 AM
Mdub707's Avatar
And it should only be used as an additive, not your only fuel source. ATF can and has been used as the fuel, not the additive. Two different topics of discussion there...
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
james2562
Oct 28, 2014 06:26 PM
