smarty or edge juice with attitude
Edge. Smarty doesn't make much power if that's what your going for. Edge allows you to monitor other engine vitals too. I have mine setup with fuel pressure fuel and intake temp and throttle percentage and its adjustable on the fly. Make sure you have a goood fuel pump output before you do either thoufgh, edge will give you a gauge fo fuel pressure sensor which is nice if you don't have gagues yet.
My Stock tranny is holding up w/ my Smarty on 4 with timing bumped to 2. I stacked Edge Comp without tapping pump and my trans wants none of it even on lvl 1x3 and Smarty on 4 w/no timing. When i pull my tractor i bump Smarty down to 2 w/no timing and it does fine pulling 8000lbs. Needless to say, the Comp will not be back on until trans is beefed up.
Depends on what condition your tranny is in but its only a matter of time....
the edge puts 120+ to the rear wheels. the vp smarty makes 65 and I think the smarty for the common rail makes 140
