2000 Cummins up and died?
Old Sep 26, 2011 | 07:35 PM
justanother92's Avatar
Default 2000 Cummins up and died?
Hey my buddy has a 00 cummins auto with 200,000+miles. Today it just quit him on the highway, he said it didnt sputter or nothin just dead. He claims he has fuel to the IP. I am gonna get my scantool tomorow and check it out. Any ideas on this would be awesom! I will post my findings. Thanks, Chad.
Old Sep 26, 2011 | 07:39 PM
empty wallet's Avatar
Having pressure at the vp means nothing, if he cracks a line, cranks it, and gets no fuel, then you know the pump quit. 99 out of 100 times when a 24v "up and dies" its because the pump went. He could pull the codes with the key trick.
Old Sep 26, 2011 | 07:46 PM
Ok well i will check the injector lines for fuel. Would you be so kind to inform me about the "Key Trick".
Old Sep 26, 2011 | 07:51 PM
turbo20psi's Avatar
Sure .. Insert your ignition key. Turn it to the OFF position. Now turn it ON, OFF, ON, OFF, ON in less than 5 seconds. Leave it in the on position. In the odometer display it should start to display codes. It starts with P PCU errors. This is to notify you that the error codes are coming. They would show up as Pnnnn. All error codes are listed in 4 digits. Write down all Pnnnn error codes that are displayed. P Done will notify that P PCU error code list is done. Now we display P ECU errors. This is to notify you that the error codes are coming. They would show up as Pnnnn. All error codes are listed in 4 digits. Write down all Pnnnn error codes that are displayed. This is notify that P ECU error code list is done. Now turn your key off.
Always make sure you see P Done Twice! It really common to see on the forums where some says "Oh my I got a P1693 and that's it" It's impossible to have just a P1693 error code by itself. So more that likely the owner saw the P Done and shut the key off and didn't allow for the ECM to display its errors.
Last edited by turbo20psi; Sep 26, 2011 at 07:51 PM. Reason: Automerged Doublepost
Old Sep 26, 2011 | 07:52 PM
Okay, he took care of it a split second before me But you wont see p-done twice because it's a 2000
turbo20psi's Avatar
For 2000-2002 Year Trucks
Ok i will sure give it a try! Thanks. Chad.
Old Sep 26, 2011 | 07:54 PM
turbo20psi's Avatar
Originally Posted by empty wallet
Okay, he took care of it a split second before me But you wont see p-done twice because it's a 2000 :tup:
Old Sep 26, 2011 | 07:57 PM
Its sure crazy how each make is so much different! I just got through fixing a 99 stroke, that high pressure oil system is so much different. One guy looked at it and said it needed a new hpop and was gonna cost 3 grand! I finally traced it down to a no fuel issue. Did not take any new parts either.
Old Sep 26, 2011 | 08:02 PM
Did you just mention a powerstroke in the 24v forum
