How much boost are you putting out.
Old Sep 26, 2011 | 06:12 PM
Smarty=Cummins's Avatar
Default How much boost are you putting out.
I have a 2001 Cummins and have a Hy35 stock turbo and wondering what kind of boost you guys are putting out in your 98 to 02 auto. trucks. I am putting out 37psi which I think is good for a Hy35.
Old Sep 26, 2011 | 08:28 PM
turbo20psi's Avatar
Thats alot for a HY. 35psi is the choke point. I was at 32si when I had mine.
I see 55psi now.
Old Sep 26, 2011 | 08:32 PM
RAW's Avatar
RAW
Much more then 32PSI and your just making a lot of hot air. What kind of EGT are you seeing?
Old Sep 26, 2011 | 08:38 PM
empty wallet's Avatar
I have my HX wastegate set for 34psi max. Nice and safe.
Old Sep 26, 2011 | 08:43 PM
turbo20psi's Avatar
I have a 64/71/14 phat shaft now. EGT's low 600 going down the highway 1200 full tilt.
Old Sep 26, 2011 | 10:18 PM
My highest egt is 1400 but I do need a Aurora 4000 for my truck and I think I would get better mpg and a little more horsepower.
What would make my truck put out that much boost. I havn't touch the turbo at all.
Last edited by Smarty=Cummins; Sep 26, 2011 at 10:18 PM. Reason: Automerged Doublepost
Old Sep 27, 2011 | 10:12 AM
GuyWithA24Valve's Avatar
Well I just have the HX35W on my truck with the wastegate hose clamped shut. At full throttle I see 30 psi and around 1,000 - 1,100 on the Pyro
Old Sep 27, 2011 | 03:40 PM
But the Hy35 in the 2001 has the wastegate built in the turbo so you can't clamp the hose off.
Old Sep 27, 2011 | 07:51 PM
aguilar_15's Avatar
They're talkin bout the hose from the wastegate to the turbo-to-intercooler boot.
Here's a pic
Attached Thumbnails How much boost are you putting out.-img_0654-1-.jpg   How much boost are you putting out.-img_0655-1-.jpg
Old Sep 27, 2011 | 07:52 PM
aguilar_15's Avatar
Not the best but it's dark out so blah
Anyways, it's the hose going from the gate to the turbo itself, that's what they mean when they say "clamped hose". In the picture, it's the blue-ish hose that you can barely see under the intake tube.
