Injector Pump Leaking Fuel
Old Sep 26, 2011 | 05:36 PM
Boojie_007's Avatar
Default Injector Pump Leaking Fuel
Anyone know why I my injector pump is leaking from a little rubber drain tube on the back of the bowl where the fuel pin is located?
Old Sep 26, 2011 | 07:43 PM
justanother92's Avatar
Well i have not had that issue i would suspect it be caused by a bad seal for the pin that is metered by the fuel pin itself.
Old Sep 27, 2011 | 10:05 AM
Boojie_007's Avatar
So is there a way to replace that? It should just be a little O ring right? Or are talking about the actual diaphram? Also, seems like where it's leaking is a drainage tube that is supposed to allow fuel out of that bowl under certain conditions.
Old Sep 27, 2011 | 07:26 PM
I am not sure on the oring i have not encountered this leak before. I bought complete Bosch oring kit for like 35 bucks. Its not very hard to take the top of pump off just know how and patience. While your in their you could do the 3200 spring!
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
WickedEvo
Oct 20, 2014 10:50 PM
