G56 noise!
Old Sep 26, 2011 | 12:35 AM
cuthbert97's Avatar
Default G56 noise!
I built a 2005 crew cab dually.
It has a 1998 12v and a g56 out of a 2006.
The tranny makes a sound while accelerating, idling, and the best way to describe it is "soda cans rattling"
Help!!! I already put a new clutch and a throw out bearing in!
Old Sep 26, 2011 | 06:33 AM
coors_man_2005's Avatar
double disk clutch??
Old Sep 26, 2011 | 10:53 AM
K80's Avatar
K80
If ids a DD or solid flywheel then its going to make some form of noise. I just ordered gorilla juice from lazarsmith to help quet it down. I'l report back if it helps.
Old Sep 26, 2011 | 11:15 AM
cuthbert97's Avatar
No it's a single disk, stock clutch.
Old Sep 26, 2011 | 03:32 PM
K80's Avatar
K80
What clutch did you use to mate the 12V to the g56? Solid flywheel or Dual Mass?
Old Sep 26, 2011 | 06:27 PM
cuthbert97's Avatar
I used the solid one that goes with the 12v.
I custom ordered a 12" clutch disk to mate with the g56.
Old Sep 27, 2011 | 06:16 AM
K80's Avatar
K80
Ok. That solid is probably whats making the noise. G56's had a dual mass flywheel to dampen transmission noises. When you had the trans out, did the input have any side-side movement?
Old Sep 27, 2011 | 07:04 AM
cuthbert97's Avatar
Not that I could remember. It only had 70k on the trans.
Well I guesss I'll be pulling the Fu$&er out and putting something else in.
4500 or 6500
Old Sep 28, 2011 | 08:59 AM
K80's Avatar
K80
Before you do that. Get in touch with lazarsmith. They are the G56 gurus. I put their gorilla juice in last night and it really shut the trans up. Shifts great too. It smells like gear lube and has the consistency of a 75W about. But if your mainshaft is "wallowing", do like everyone else and run it till it blows.
Transmission
Linky
Old Sep 28, 2011 | 06:36 PM
cuthbert97's Avatar
Hahhahaa ill try that,
I can't really run it till it blows. I rely on my truck everyday for work. Pipeline welder .
Where can I pick some of
That up?
