INSTRUMENT CLUSTER
Old Sep 25, 2011 | 11:00 PM
ADRIAN's Avatar
Default INSTRUMENT CLUSTER
do anybody or some who reads this can help me find an cluster for my 96 dodge 3500 cummins...manual trans....been looking all over the place a;so googled it for some hours nowan still ant find anything so if u c this pls help : the problem im having is my speed an gas heands dont work ..i check connettions an changed the speed sensor out an still no good so im thinking the cluster itseft is bad.or could it be the green power board on the back...im lost on this hole thing so help pls
Old Sep 25, 2011 | 11:32 PM
H.R.D's Avatar
eBay my friend.
Old Sep 26, 2011 | 12:36 AM
Sudia247's Avatar
I have a gauge cluster out of a 94 2500. Im using the truck as a donor truck and wont be needed the gauge cluster. The truck came with no engine so I have no idea if there is any problems with because Ive never seen it in use.
Old Sep 26, 2011 | 05:39 AM
ADRIAN's Avatar
i have checked ebay an all they have is one for an reg trans an i have an manual trans an sudia247 can u take sum pics an send it to my email
Old Sep 26, 2011 | 04:13 PM
Sudia247's Avatar
Well it shouldnt matter what tranny you have for the guage cluster. Its what engine, either gas or diesel. The one I have is for a diesel. Whats your email?
Old Sep 26, 2011 | 07:16 PM
ADRIAN's Avatar
adrianparker98@gmail.com
an i have the cummins
Old Sep 26, 2011 | 10:18 PM
Sudia247's Avatar
Email sent.
Old Sep 27, 2011 | 12:39 AM
H.R.D's Avatar
Actually it does an auto has the gear selector window in the cluster were a manual does not.
Old Sep 27, 2011 | 01:42 AM
Sudia247's Avatar
Yes you are correct, but I was referring to actual function for his application. In a manual transmission truck, either the auto or manual cluster can be used to full benefit. Just if it was the auto cluster the gear selector would be unused. Most cover it or replace it with the manual plastic cover. I should of been more specific, thanks for the correction.
Old Sep 27, 2011 | 02:11 AM
H.R.D's Avatar
for the highlighted section.
Wasn't trying to correct you per say. Just making sure Adrian knows the gear selector will be on an auto cluster.
