TPPS adjust, now codes
Old Sep 25, 2011 | 03:16 PM
Gamecocks's Avatar
Default TPPS adjust, now codes
Codes p1693, 0122, and 1698 show up.
I did the TPPS adjustment, didnt have the codes before. Check engine light went away after a few minutes. Truck doesnt run/idle different and shifts are the same. Only thing that changed is now when i can acclerate normally and it smokes like im doggin on it, also it smokes in Neutral now and didnt before...
I have a feeling these codes are very minor but wanted to check with the pros...
Thanks for the help!
Old Sep 25, 2011 | 03:36 PM
empty wallet's Avatar
0122 means apps voltage too low, did you probe the wire again after bolting the apps housing back on? Sometimes it could move if you arent careful. 1698 means no signal from pcm, could be a short circuit, bad ground, etc
Old Sep 26, 2011 | 04:31 PM
Gamecocks's Avatar
yeah i double checked the volts, should be at .531 i set it to .535
i checked to the plug, thinking it might not have been seated but it was. ill check whatever ground come out of that harness. 1693 is just a companion code right?
i did the tpps "reset", disconnect neg battery cables, leave key ON for 30 mins, turn key off, hook up the cables, turn key back on and slowly press the gas to the floor then slowly release....
Still got the codes. Any other suggestions?
ok so i got the codes cleared now the truck seems to smoke more than normal, is it the ecm relearning or do i have a problem? Sorry for the stupis questions but this truck is new to me
asajay
Sep 10, 2015 12:08 AM
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
Daniel Leipart
Jun 28, 2015 02:42 PM
schwier94
Mar 8, 2015 06:09 PM
Renowest48
Dec 14, 2014 08:36 PM
