Front rotors.
Old Sep 25, 2011 | 12:19 PM
hoeky22's Avatar
Default Front rotors.
How do I remove the front rotors on my 1998 dodge ram 2500 12 valve 4x4. I need to get to the ABS sensor.
Old Sep 26, 2011 | 04:47 PM
1AMatt's Avatar
Site Sponsor - 1aauto
The whole wheel bearing needs to come off, and you have to separate the rotor from the hub by removing the wheel studs... Not fun
Old Sep 26, 2011 | 08:12 PM
Jerroh's Avatar
Hub nut is 1 11/16 and u will need an impact wrench or 3/4 drive breaker with a cheater, I broke a 1/2 drive breaker easily. The 4 bolts behind the hub are 14 mm 12 point, if u dont have a hub puller then Unscrew them a few turns then put the socket on and use a hammer, might need an extention on the socket, I did. go around all 4 tapping and backing them out until the hub comes off. Once the hub is off use a brass or copper mallet or a chunk of softer metal as a buffer to hammer them out so u dont ruin the lug studs. They werent to bad to get out for me. Be carefull with the 4 hub bolts as they are a dealer item and last time i checked they cost $20 a piece. I asked if they were made of gold but the parts dealer at dodge didnt think that was funny. which made us even cause i didnt enjoy being bent over for a bolt . next time i will ask for a reach around.
Old Sep 28, 2011 | 11:38 AM
hoeky22's Avatar
Ok thanks thats a terrible set up. Ill keep ya posted on how it goes.
Old Sep 29, 2011 | 02:45 PM
1AMatt's Avatar
I have used an air hammer to get the studs out and in... Seems to work pretty good
Old Sep 29, 2011 | 09:50 PM
tiremann9669's Avatar
Good point on the bearing bolts, when I changed my bearings I bought a longer bolt the same size to hammer on that way I didn't mess up my bolts.
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
Natenelson1
Jan 19, 2015 07:23 PM
2FordStrokers
Jan 11, 2015 09:40 PM
