Defrost Isn't Working
Old Jan 9, 2008 | 11:22 AM
Jazz's Avatar
Default Defrost Isn't Working
This morning I start my truck and let it defrost but I only have defrost working on drivers side. Everything else blows on both sides. What gives?
Old Jan 9, 2008 | 10:27 PM
websterdan's Avatar
I'm having similar problem: Fan only blows out of vents, seems A/C is always on. Been told it's either the door to select location of air, the actuator motor or possibly vacuum pump.
Old Jan 9, 2008 | 10:55 PM
Uncle Bubba's Avatar
Generally when you have a problem with these vent doors they only blow out of the defrost. They are vaccuum operated and designed to default to the defrost vents when something goes wrong, this is for safety purposes. So to not be able to geet air out of the defrost is rare. Almost gotta be something blocking them which would mean pulling the dash I suspect.
Old Jan 10, 2008 | 12:42 AM
Monster Truck's Avatar
Check to make sure the actuator is free, look under the drivers side of the dash and you will see if up under there above the floor vents, you can actuate it by hand.
Old Jan 10, 2008 | 06:43 AM
Jazz's Avatar
I'll check the actuator but I would think its alright because it will go to vents floor and to defrost. Blows good on every setting but defrost. Can't figure why it would only blow on defrost on drivers side. I guess it could be worse and only blow on passengers side Thanks for the replies. If it isn't the actuator I'm not pulling the dash until spring.
Old Jan 10, 2008 | 10:07 AM
If it gets to that - make sure you change the heater core while you are in there.
Old Jan 11, 2008 | 07:25 AM
Jazz's Avatar
Actuator is free as I figured because it will switch between defrost vents and floor. What I don't understand is why do I have air blowing in all vents (both sides) on everything but defrost where it only blows on drivers side. I've never had a dash out before to see how the system actually works. Looks as tho this Spring I'm about to
Old Nov 26, 2008 | 08:55 PM
amo 426's Avatar
happened to my 04 an the door that operates the defrost door broke,big job
Old Nov 26, 2008 | 09:12 PM
davo79's Avatar
buddy of mine found a rats nest in his was way funny when he found it hes all girly when it comes to critters
Old Nov 26, 2008 | 10:17 PM
stkdram55's Avatar
you dont have a porno covering up your vent do ya
