Any help in advancing my timing??
Old Sep 24, 2011 | 05:15 PM
Sudia247's Avatar
Default Any help in advancing my timing??
I am currently rebuilding my truck from the ground up. Im starting the engine work as I replace all the gaskets and rebuild some things. After I get my engine back together, I wanted to advance the timing on my pump to 16.5*. I have a barring tool but not the gauge and everything you need to calculate the timing. I was wondering if anyone that was in the Sacramento area had these tools, and would be kind enough to lend me them or even help me time the pump. Id like to know how to do this so down the line I can time future engines.
Thanks!
Old Sep 24, 2011 | 10:08 PM
dshane62's Avatar
set #1 on tdc with timing pin.
lock pump with the pin that you turn over on pump.
take gear loose.
where you turned the pin around on the pump there is 2 screws that hold the whole
piece to the pump loosen the screws then slide that piece down about .025 to .030 tighten the screws , put gear back on turn the locking pin around on the pump,
pull the timing pin on geartrain back out. that will put you at 15 - 16 advanced the easy way.friend of mine that does pumps on a machine showed me that.
i did mine that way worked good. hope that will help
Old Sep 26, 2011 | 01:00 AM
Sudia247's Avatar
Is that reliable though? A little bit to much of movement and timing could be way to advanced an I can do more harm then good... Im not a fan of eyeing measurements or guessing when there is a proper way....
Old Sep 26, 2011 | 01:32 AM
Jerroh's Avatar
I gotta second that and would like to know also seeing as my idle is low i will adjust a bit
Old Sep 26, 2011 | 02:23 AM
Sudia247's Avatar
Here is to your idle problem.
Ram Diesel Problems
Old Sep 26, 2011 | 01:49 PM
dshane62's Avatar
Default adv
well im just telling you the easy way if you cant figure 025 then i guess you should go pay
150 - 200 bucks to have it done but a lot of guys that you take it to will do it that way
Old Sep 26, 2011 | 04:24 PM
Sudia247's Avatar
Im just saying they have gauges for timing for a reason, so its spot on. Measuring isn't the problem here, accuracy is. You stated before it will be between 15 and 16*. That's not accurate enough for me. I want 16.5* and that's it; with proper tools its easy to do. Thanks for your advice, Im not trying to go against you in any way. I just like things to be done the best they can be done. I posted this thread in search for someone near by if they would be kind enough to help me out if they had the tools needed. If it comes down to it, I'll just spend the $150 on the right tools so I can do it myself.
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
91 7three
Nov 14, 2014 10:37 PM
jjbced
Oct 26, 2014 09:09 PM
