voltage regulater/ECM/PCM
Old Sep 24, 2011 | 12:46 PM
cummins_guy's Avatar
Default voltage regulater/ECM/PCM
Well, I fell victim to the voltage regulater, after doing alot of searching and trying to find the better route to take, I have a company that will rebuild your ECM for around 150.00 and give a lifetime warranty.
there phone number is
1-866-983-6688
Old Sep 25, 2011 | 12:39 PM
cougar's Avatar
You can just bypass it and install a 91 or older stand alone regulator for a third of that.
Old Nov 20, 2013 | 06:34 AM
master6789338's Avatar
Default pcm bypass
can you hook up power to a wire comming from the pcm to power the speedo and o/d? what if you have a three wire speed sensor? isn't one of the wires supposed to have 8 volts going to it ? I can't remember what sites had it supposedly you can just hook up 12 volts where you are supposed to have 8 volts supply power. will that work also? truck has auto trans.
Old Nov 20, 2013 | 11:55 PM
Nevadan's Avatar
I'm new to the Dodge Cummins and would like to hear an answer to master6789338's question. I'm replacing a 1991 engine with another 1991 engine and there's a difference in the ECM's on the trucks they came out of. On my truck the ECM is in the driver's side fender well behind the battery. On the truck I got my new engine form there's a very small ECM?? mounted to the firewall below the brake booster. I've got to figure out a way to wire this in. I also have a fairly well hacked and spliced engine bay wiring harness to go through. The cold start timing advanced was just wired into the same terminal as the regular pump shutoff valve so there's obviously some corrections I need to make.
I do like the idea of being able to repair the ECM for $150 and will look into that once I get the wiring corrected.
john grossman
10
Jan 12, 2019 08:58 PM
Saams69
Jul 20, 2015 11:21 PM
91firstgen
May 2, 2015 01:07 PM
robbyS
Apr 16, 2015 02:22 PM
Big _red _cummins
Nov 17, 2014 02:44 PM
