2001 47RE Slipping in Left Hand Turns
Old Sep 24, 2011 | 11:11 AM
cartboy's Avatar
Default 2001 47RE Slipping in Left Hand Turns
I normally just lurk on the website but I have come up on a problem with my 01 3500. I searched the threads for something similar but didn't find anything, sorry if this has been asked a thousand times. The trans is starting to slip but it only happens when I am in a left hand turn. I recently changed the fluid/filter and the fluid level is normal. I am showing ECM codes P0122 and P1698, I don't think either of these are really related to my issue. Is there something I am missing? Any suggestions are appreciated.
Old Sep 24, 2011 | 11:32 AM
mysterync's Avatar
Default Re: 2001 47RE Slipping in Left Hand Turns
Are you positive its a trans slip?
Old Sep 24, 2011 | 01:30 PM
cartboy's Avatar
As far as I can tell it is, the engine revs and the truck doesn't pick up speed and then it will grab and jerk forward.
Old Sep 24, 2011 | 09:18 PM
lauber_03's Avatar
sounded like rearend at first but not to sure on that. Limited slip maybe kicking in hard?
Old Sep 24, 2011 | 11:20 PM
dieseldude848's Avatar
does it do it when its cold or hot? mine will do it if its been sitting, and if i take off heavy on a turn. i was told that the trans oil pump cant lift the oil out of the pan when cold on a turn because theres not enough in there for it to suck when cold. causing it to act like it goes in and out of gear.
Old Sep 25, 2011 | 05:43 AM
cartboy's Avatar
it happens when it is cold and when its hot. my first thought was that it was low on fluid, so i checked it again, it is at a normal level.
Old Sep 25, 2011 | 09:14 AM
mysterync's Avatar
And your sure the filter is sealed against the vb well? All the vb wiring is intact?
Old Sep 25, 2011 | 10:12 AM
cartboy's Avatar
i looked over the wiring when i had the pan and filter off to change it. it appeared to be in place and i didn't find any wiring that looked mashed or messed up. the filter was tight against the valve body when i replaced it, i tried to wiggle it to make sure it was seated and tight. i plan to do the filter and fluid again after i finish hauling firewood for this year and check the adjustment on the bands as well. I won't do that for another month or so though.
Old Sep 25, 2011 | 10:15 AM
mysterync's Avatar
Did this start with the fluid filter replacement or was.it the reason for the replacement
Old Sep 25, 2011 | 10:17 AM
cartboy's Avatar
it was the reason for the replacement. I really hoped that it would help the issue but it still does the same thing.
