new lift pump in tank
Old Sep 24, 2011 | 01:04 AM
ebbtide357's Avatar
Default new lift pump in tank
just changed lift pump in tank because lines were rotted with airtex had no problems beforehand just leaked if i filled up changed quick connect with new gas line and clamps started up after i was done 15 seconds shut off tried to bleed at ip nothing bled on outlet side of filter nada loosened filter up nothing coming out this is the truck with pump in tank and on block also can hear pump on engine coming on does the one in tank come on because i cant hear it? thinking maybe air block from pump in tank to block pump or weak pump on the block its stuck at friends house going over in morning with 5 gallons of diesel and new filter i know these are supposed to self bleed by bumping starter on and off i will be upgrading to new airdog or fass when moneys right but needed to fix these lines anyway.any help PLEASE
Old Sep 24, 2011 | 09:33 AM
empty wallet's Avatar
I'm trying to comprehend all of this.... you have in tank and didn't remove old pump from engine bay? Why not? The intank pumps are pretty weak, but I'm not sure how you can have both. If the one in the engine bay is turning on than you don't have power to the one in the tank (I'm GUESSING) because I'm pretty sure theres only 1 plug
AND if I'm right, your FACTORY lift pump is trying to pull fuel thru the in tank pump, which it cannot do (because nothing can pull fuel thru a non operating electric pump.) So that should be your solution.
Did you unplug harness to factory pump and plug it into the harness Dodge gives you with intank pump (has inline fuse that comes off battery, uses same connection for power?)
Old Sep 24, 2011 | 10:01 AM
mysterync's Avatar
Default Re: new lift pump in tank
That airtex will fail very quickly! If your going this route make sure you have fuel pressure gauge or you will be buying a 1200.00 vp44.
As said above, you would have to install the mopar retrofit kit if you have a on the block carter.
We just installed a fass direct replacement pump on a 5.9l yesterday. It's a much higher quality product, Comes with a 4 year warranty , and is in the same price range as most factory replacements. I would consider one of these. Most auto parts stores will return the airtex with no questions asked.
Old Sep 24, 2011 | 04:20 PM
ebbtide357's Avatar
thanks guys for the response just bought the fass platinum need this truck for work monday im gonna drop the tank pull out the airtex and return it the only reason i changed it was the lines rotted out. with this fass i also got the draw straw so im gonna put the old module back in after i seal it all up so i have the fuel gauge the only thing that concerns me is the drilling into the frame to mount this pump what do you think?
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
