Gauge install help
Old Sep 23, 2011 | 08:39 PM
atticusfield's Avatar
Question Gauge install help
So i bought a set of glow shi*s and was wondering if anyone knows where to connect the pressure sending unit to an air dog II? is there an easy spot to just thread them in or do i need to tap into the line and make a "T"? Also i have heard that there is an already threaded hole to attach the boost gauge fitting, does anyone have any info on this or do i need to tap and drill myself?
Old Sep 23, 2011 | 08:59 PM
mysterync's Avatar
Default Re: Gauge install help
Order a boost bolt and use it in place of an existing manifold bolt. Use a t inline a ways back from the pump to avoid pulsations that effect the reading. The fitting sizes should be 1/8npt
Old Sep 23, 2011 | 09:48 PM
Get a tapped 90 degree fitting that connects to your vp44.
Luke
Old Sep 23, 2011 | 09:49 PM
mysterync's Avatar
Isn't it a 12v truck?
Old Sep 23, 2011 | 10:08 PM
I can't tell using Tapatalk
Luke
Old Sep 23, 2011 | 10:28 PM
mysterync's Avatar
Lol you have that problem to eh... it just said it was in 12v forum.
Old Sep 23, 2011 | 10:33 PM
Lol.... I see that now
Luke
Old Sep 23, 2011 | 10:56 PM
pukie370's Avatar
make shure you tap in after the fuel filter, so you have correct reading to pump.
Old Sep 24, 2011 | 12:27 AM
so can they be clamp connections?
Old Sep 24, 2011 | 10:06 AM
mysterync's Avatar
I prefer pushlock fittings . Eaton is available at Napa. Other brands are available on the vendor section od this website, or summit / jegs
