Boost Elbow Question
Old Sep 23, 2011 | 05:50 PM
smoking12valve's Avatar
Default Boost Elbow Question
ok...so i bought an adjustable boost elbow for the truck. i really didnt no where it goes...so i searched some forums..and i got two different answers. on the compressor side of the turbo(where i have it now) and on the back side of the injection pump. can someone please clear this up for me? it seems to be workin where i have it..most ive seen so far is 25lbs of boost. i know its wastegated at 19lbs.
thanks in advance everyone.
Old Sep 23, 2011 | 06:17 PM
turbo2332's Avatar
mine is on the pump but it really doesnt matter as long as it is installed in that thine from the turbo to the back of the pump. all it is doing is bleeding off pressure to fool your wastegate. the way you have it should be fine.
Old Sep 23, 2011 | 10:05 PM
daveO's Avatar
The correct spot for it is on the compressor housing of the turbo. There's a line running from an elbow going to the wastegate actuator. Unhook the line, unthread the elbow and replace it with your adjustable one.
Old Sep 23, 2011 | 10:32 PM
mysterync's Avatar
Default Re: Boost Elbow Question
Actually the correct spot is either. Some trucks had compressor mounted reference lines and some had afc mounted reference lines. We sometimes will drill and tap the compressor to eliminate the hard line but unless its busted there is no reason really. Again, the trucks can be setup either way so there is no right or wrong answers
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
somarillw
Dec 4, 2014 12:37 AM
joshkhouse80
Nov 21, 2014 01:17 AM
scottxmorris
Nov 11, 2014 03:28 PM
