Pop testing injectors
Old Sep 23, 2011 | 04:02 PM
South Tx Coal Roller's Avatar
Default Pop testing injectors
I've been thinking about having my stock injectors pop tested and shimed if needed. The truck has 263,xxx miles on it and have no idea if they have ever been tested. Local pump shop will do it for $9 an injector. I'll get the timing bumped up too while I'm there.
Is it worth it to get the injectors tested?
Old Sep 23, 2011 | 10:06 PM
daveO's Avatar
It definitely wouldn't hurt IMO.
Old Sep 23, 2011 | 10:20 PM
That's kind of what I was thinking. Found out the $9 an injector was for installing new nozzles, setting them up, and pop testing. May have to order up a set of 5x.012 SDX nozzles, my trans is going to hate me though.
Old Sep 24, 2011 | 03:03 AM
Al31031's Avatar
have you ever had the front and rear bands adjusted on the tranny
Old Sep 24, 2011 | 08:35 AM
Not yet. I have a DTT shift kit that's going in ASAP, I planned on adjusting the bands then.
Old Sep 24, 2011 | 06:29 PM
Al31031's Avatar
do you still have the check valve in the tranny cooler line?
Old Sep 24, 2011 | 06:31 PM
As far as I know.
Old Sep 24, 2011 | 06:36 PM
Al31031's Avatar
rip it out by pass it tranny killer!!!!
Old Sep 24, 2011 | 06:46 PM
I take it you found that out the expensive way? Lol
Old Sep 24, 2011 | 06:50 PM
Al31031's Avatar
yes yes yes rather not talk about that but i will say it hurts more the second time its on the return line to the tranny from the cooler what happens all to often is they stick or other malfunctions and will overheat your tranny without you ever knowing about it and by the time you do know its too late iv had it happen to me like i said and it sucks some drill it some make their own there are kits but deff kill it before it kills your tranny!!!!
