Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
'05 duramax loosing fuel pressure
Old Sep 23, 2011 | 09:57 AM
Jay Bumpus's Avatar
Default '05 duramax loosing fuel pressure
have fuel issues with a `05 gmc 4500 duramax. truck looses prime and stalls at low rpm
Optional Information:
Make: GMC
Model: 4500
Year: 2005
Engine: duramax diesel
Already Tried:
r&r fuel tank and cleaned,new fule lines tank to engine, new cp3 pump assembly,replaced the check vale unit in filter houseing,new injectors (8),
Old Sep 23, 2011 | 03:03 PM
2500HeavyDuty's Avatar
did you rebuild the filter housing?
do you have a scan tool to monitor rail pressure??
Old Sep 25, 2011 | 12:19 PM
Jay Bumpus's Avatar
We did rebuild the filter housing and the readings i got on the scanner are:
des frp (mpa) - 1235 {at 1200 rpm}
act frp (mpa) - 1220-1240 {at 1200 rpm}
des frp (ma) - 35 {at 1200 rpm}
act frp (ma) - 35 {at 1200 rpm}
Old Sep 28, 2011 | 06:10 PM
Dirtbikindad393's Avatar
FormerVendor
Have you checked to make sure the water in fuel sensor is not cracked?
Old Sep 29, 2011 | 10:49 AM
Jay Bumpus's Avatar
We replaced the water separator sensor with a new one
Old Sep 29, 2011 | 11:26 AM
Cbum's Avatar
temporary install a section of clear fuel line on inlet an outlet of filter housing and check to see if you are getting air bubbles in fuel before or after housing.
Old Oct 15, 2011 | 09:33 AM
Jay Bumpus's Avatar
well, we ran some more tests and come to find out, the brand new cp3 was defective! So we replaced that and now it works great, so thank you all for your help!!! its actually nice seeing this truck drive out of the driveway!! Thanks again!
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
