Need some help with T Case or Possibly Front Differential
Old Sep 22, 2011 | 10:41 PM
DC_DC41's Avatar
Default Need some help with T Case or Possibly Front Differential
Alright my 04.5 has a constant whine noise that I just can't put my finger on. After a little investigating the first thing I did was take the front drive shaft out and drive it in 2WD and just like that, no noise so naturally you would think replace the three u joints on the front drive shaft and problem solved. I did that, reinstalled and the noise is back . I am now offically stumped...I never ran the truck in 4WD when the driveshaft was out so i'm going to try that tomorow. If it makes the noise then I would assume it is in the transfer case. Any thoughts or ideas on this willd be appreciated!!!
Old Sep 23, 2011 | 06:52 AM
coors_man_2005's Avatar
even locking it in with the front drive line out the front axle is going to still lock in im not sure if they run off vacum or electric anymore but i would unhook the front accuator and lock it in and then hook it back up and lock it in to check the frontend
Old Sep 26, 2011 | 11:09 PM
Daggy's Avatar
Transfer case won't make noise without the front drive shaft in. Mine case was shot, pulled the drive shaft, put it in 4wd and drove around, didn't make a sound. Have you checked the fluid in the case, diffs, etc?
Old Sep 28, 2011 | 10:32 PM
DC_DC41's Avatar
Turns out it was the outer pinion bearing. What a project...both axles and the third member came out. I had to install a race, crush sleeve and seal. While I was at it I did the two u joints on the axles also.
Old Sep 29, 2011 | 12:33 PM
tangodown's Avatar
That sucks, but at least you found out what it was. Plus it gave you a good excuse to replace the U joints and new racing. And now that whine is gone!
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
DirtyDiesel58
Jun 7, 2015 11:50 PM
Natenelson1
Jan 19, 2015 07:23 PM
