Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
CENTRAL & S.E. OHIO PULLERS "08" RULES
Old Jan 9, 2008 | 07:00 AM
PERFORMANCETRUCK's Avatar
Default CENTRAL & S.E. OHIO PULLERS "08" RULES
PERFORMANCE TRUCK & TRACTOR PULLING SERIES
740-819-6200
740-468-9045 FAX
RULES FOR 2008
6200LB "CHEATER STOCK” GAS 4X4
ENGINES & DRIVETRAIN
1. BLOCKS AND HEADS MUST BE CAST IRON.
2. ALUMINUM INTAKES, SINGLE FOUR-BARREL CARBURETORS AND EFI PERMITTED.
3. 4500 SERIES DOMINATORS, TURBOS AND SUPERCHARGERS ARE NOT PERMITTED.
4. HEADERS PERMITTED WITH MUFFLERS AND MUST EXIT BEHIND CAB.
5. ENGINE MUST BE SAME MAKE AS TRUCK AND IN STOCK LOCATION.
6. 514 CU. IN. LIMIT.
7. TRANSMISSION AND TRANSFERCASE MUST BE OEM, 1 TON OR LESS.
8. FRONT AND REAR AXLES MUST BE OEM, 1 TON OR LESS.
CHASSIS
1. FACTORY FRAMES 1 TON OR LESS REQUIRED WITH COIL OR LEAF SPRINGS FRONT AND REAR.
2. TRACTION BARS ARE PERMITTED.
3. REAR SUSPENSION BLOCKS ARE NOT ALLOWED.
4. CREW CAB AND EXTENDED CAB TRUCKS ARE PERMITTED.
WEIGHTS
1. NO FRONT WEIGHTS, HEAVY PIPE BUMPERS, BRUSH GUARDS, OR SNOW PLOWS.
2. WEIGHTS MUST BE SECURED IN BED, NOT IN CAB OR IN ENGINE COMPARTMENT.
HITCH
1. HITCH POINT MUST BE A MINIMUM OF 48” FROM THE CENTER OF THE REAR AXLE AND A MAXIMUM OF 24” HIGH.
2. NO PART OF HITCH CAN EXTEND FORWARD PAST THE CENTER OF THE REAR AXLE AND NO HITCH ADJUSTMENT PERMITTED FROM REAREND.
TRUCK
1. MUST HAVE COMPLETE FACTORY SHEET METAL AND WINDOWS.
2. NO REMOVING OF BED FLOOR.
3. FLAT BEDS ARE PERMITTED AS LONG AS THEY ARE FACTORY BUILT OR HEAVIER.
4. FIBERGLASS HOODS AND HOOD SCOOPS PERMITTED.
5. BATTERIES AND FUEL TANKS MUST BE IN STOCK LOCATION OR IN BED.
TIRES
1. ANY STREET LEGAL DOT APPROVED TIRE IS PERMITTED.
2. MAXIMUM TIRE SIZE 36” TALL X16” WIDE.
3. NO CUT OR SHARPENED TIRES ALLOWED.
SAFETY
1. NO NITROUS OR ANY PRESSURIZED FUELS.
2. PUMP GAS OR RACING GAS ONLY. NO ALCOHOL OR NITRO PERMITTED.
3. DRIVE SHAFT LOOPS, U-JOINT SHEILDS, BLOWPROOF BELLHOUSING OR TRANSMISSION BLANKETS ARE REQUIRED AND KILL SWITCHES ARE MANDITORY FOR EVERYONE’S SAFETY.
_________________
PERFORMANCE TRUCK 740-819-6200
740-819-6200
740-468-9045 FAX
RULES FOR 2008 & 2009
6500LB “PRO STREET” 4X4
1. CAST IRON BLOCKS ONLY, ALUMINUM INTAKES, ANY CAST IRON OR CONVENTIONAL TYPE ALUMINUM CYLINDER HEADS PERMITTED. NO PRO STOCK TYPE CYLINDER HEADS, SHEET METAL, OR TUNNEL RAM INTAKES PERMITTED. NO DRY SUMP OILING SYSTEMS.
2. A 585CU. IN. LIMIT WILL BE ENFORCED.
3. DOMINATOR CARBS. PERMITTED. NO TURBOS, SUPERCHARGERS, INJECTION, EFI, SPLIT OR DUAL CARBS.
4. OPEN HEADERS PERMITTED MUST EXIT DOWN AND BACK.
5. ENGINE MUST BE SAME MAKE AS TRUCK AND THE BACK SIDE OF THE BLOCK MUST BE ATLEAST 15" BEHIND THE CENTER OF FRONT AXLE.
6. TRANSMISSION, TRANSFERCASE FRONT, AND REAR END MUST BE OEM, 1 TON OR LESS.
7. HEAVY DUTY AFTERMARKET DRIVETRAIN PARTS CAN BE USED IN OEM HOUSINGS.
CHASSIS
1. FACTORY FRAMES ONLY NO TUBE CHASSIS.
3. SOLID OR BLOCK SUSPENION PERMITTED FRONT AND REAR.
WEIGHTS
1. FRONT WEIGHTS AND BRACKETS MAY NOT EXTEND MORE THAN 195 INCHES FORWARD FROM THE CENTER OR REAR AXLE.
2. THIS MEASUREMENT IS USED TO COMPENSATE FOR ALLOWING LONGER WHEELBASE TRUCKS TO COMPETE.
HITCH
1. HITCH MUST BE A MINIMUM OF 36” FROM THE CENTER OF THE REAR AXLE AND A MAXIMUM OF 24”-26"HIGH DEPENDING ON EVENT.
2. HITCH CAN BE ADJUSTABLE, BUT IT MUST BE STATIONARY IN ALL DIRECTIONS WHEN PULLING.
TRUCK
1. CAB MUST HAVE FACTORY SHEET METAL AND WINDOWS.
2. MUST HAVE GOOD SOLID BED FLOORS.
TIRES
1. ANY STREET LEGAL DOT APPROVED TIRE.
2. MAXIMUM TIRE SIZE IS 36” TALL X 16” WIDE.
SAFETY
2. PUMP GAS OR RACING GAS ONLY, NO ALCOHOL OR NITRO PERMITTED.
3. DRIVE SHAFT LOOPS, U-JOINT SHEILDS, BLOWPROOF BELLHOUSING OR TRANSMISSION BLANKET AND KILL SWITCHES ARE REQUIRED.
740-819-6200
740-468-9045 FAX
RULES FOR 2008
8000LB. "STREET LEGAL DIESEL" 4X4 CLASS
1. TRUCKS CAN BE TRAILERED IN, BUT MUST MEET THE REST OF OUR RULES FOR THE STREET LEGAL CLASS.
2. TRUCKS COMPETING IN THIS CLASS MUST BE STOCK IN APPEARANCE.
3. ENGINE, AND DRIVETRAIN MUST COME FACTORY IN A 1 TON OR LESS PICKUP.
4. THIS CLASS IS LIMITED TO A SINGLE CHARGER. THE INDUCER BORE CAN'T EXCEED 2.60". THIS WILL BE TECHED USING A 2.65" PLUG, IF THE PLUG GOES IN YOU WILL BE DISQUALIFIED. THE LARGEST DIAMETER OF THE INTAKE COMPRESSOR WHEEL MAY NOT EXCEED 100mm. NO REDUCERS OF ANY KIND PERMITTED TO MAKE A LARGER TURBO PASS INSPECTION. THIS ALSO INCLUDES WELDING AND REMACHINING INDUCER BORE TO MAKE A LARGER TURBO PASS. THE STOCK MAP WIDTH ENHANCEMENT (MWE) GROOVE IS ALLOWED. NO MWE GROOVE WIDER THAN A 1/4" WILL BE PERMITTED. NOTE LARGER CHARGERS AND TWINS ARE PERMITTED AS LONG AS THEY ARE O.E.M. FOR THAT YEAR OF TRUCK.
5. DIESEL FUEL AND BIO DIESEL ARE THE ONLY FUELS PERMITTED IN THIS CLASS.
6. SMOKE MUST EXIT UP THROUGH STACKS OR YOU WILL NEED A TURN UP ON YOUR TAIL PIPE. NO EXCEPTIONS!!!
7. SUSP. MUST HAVE 1" OF TRAVEL. TRACTION BARS ARE PERMITTED AS LONG AS THEY DON'T RESTRICT SUSP. TRAVEL.
8. MUST PULL OFF OF A REESE TYPE HITCH, MOUNTED SOLID TO THE FRAME W/NO MOVEMENT. HOOKING POINT MUST BE THE FURTHEST POINT BACK OF THE TRUCK AND A MAXIMUM OF 26" HIGH.
9. FRONT WEIGHTS AND BRACKETS CAN'T EXCEED 60" FROM CENTER OF FRONT AXLE.
10. ANY D.O.T. APPROVED TIRE IS PERMITTED. NO CUTTING OR SHARPENING OF TIRES PERMITTED.
11. NO NITROUS, PROPANE, OR ANY OTHER PRESSURIZED FUEL PERMITTED. ANY TANKS, LINES, OR ETC. MUST BE REMOVED FROM TRUCK BEFORE COMPETING.
12. MANDITORY SAFETY: ALL TRUCKS MUST HAVE 6" LONG U-JOINT SHIELDS COVERING REAR END YOKE, REAR OUT PUT YOKE, FRONT OUT PUT YOAK, AND FRONT END YOKE. THE FRONT OUT PUT YOKE COVER IS NOT REQUIRED IF LACK OF ROOM PEVENTS INSTALLATION. SHIELD THICKNESS REQUIREMENTS ALUMINUM MIN. 5/16" AND STEEL MIN. 1/4".
740-819-6200
740-468-9045 FAX
RULES FOR 2008
8000LB. “PRO STREET” 4X4
1. TRUCKS COMPETING IN THIS CLASS MUST RUN TRANSMISSIONS, TRANSFERCASES, FRONT ENDS AND REAR ENDS THAT CAME FACTORY IN A 1 TON OR LESS PICKUP. HOWEVER THE INTERNAL DRIVETRAIN PARTS CAN BE UP GRADED AND MODIFIED.
2. ENGINES MUST BE OEM AND AVAILABLE IN 1 TON OR LESS PICKUPS. NO AFTERMARKET HEADS OR BLOCKS PERMITTED.
3. NO SIGMA INJECTOR PUMPS PERMITTED.
4. SINGLE CHARGERS ARE LIMITED TO A 3.0" INDUCER BORE. THIS WILL BE TECHED USIN A 3.05" PLUG.
5. LIMITED TWIN CHARGER SET UPS ARE PERMITTED AS LONG AS THEY FIT THESE RULES. TOP CHARGER MUST BE A DIRECT BOLT ON AND THE BOTTOM CHARGER MUST HAVE A 3" OR SMALLER INDUCER BORE AND WHEEL SIZE. NO RESTRICTORS OF ANY KIND MAYBE USED TO PERMIT A LARGER TURBO TO PASS INSPECTION. A 3.05" PLUG WILL BE USED TO TECH THESE TRUCKS.
6. NO NITROUS, OR PROPANE. ALL TANKS AND LINES MUST BE REMOVED FROM TRUCKS BEFORE COMPETING.
7. FRONT WEIGHTS AND BRACKETS MAY NOT EXCEED MORE THAN 60" FROM CENTER OF FRONT AXLE.
8. REAR SUSP. BLOCKS AND TRACTION BARS ARE PERMITTED.
9. PULLING TYPE HITCHES ARE PERMITTED, HOOK POINT ATLEAST 36" BEHIND THE CENTER OF REAR AXLE.
10. ANY D.O.T. APPROVED TIRE PERMITTED. NO CUTTING OR SHARPENING OF TIRES PERMITTED.
11. SAFTEY REQUIREMENTS. MUST HAVE DRIVE SHAFT LOOPS AND U-JOINT SHIELDS ON FRONT AND REAR SHAFTS. BLOWPROOF BELLHOUSINGS, OR BLANKETS OR BELLHOUSING SHIELDS REQUIRED. AIR OR FUEL SHUT OFF KILL SWITCHES REQUIRED.
12. SMOKE MUST EXIT STRAIGHT UP. TURN UPS REQUIRED ON TAIL PIPES.
"2008"
7500-8000LB. OPEN 4X4 GAS/DIESEL RULES
1. 26" HITCH MAX
2. ALL SAFETY SHEILDS BELLHOUSINGS, BLANKETS AND KILL SWITCHES REQUIRED.
3. NO CRYING!!!!!
Last edited by PERFORMANCETRUCK; Jan 9, 2008 at 07:02 AM. Reason: Automerged Doublepost
