New transmisson has a problem?
Old Sep 22, 2011 | 07:59 PM
STDiesel59's Avatar
Default New transmisson has a problem?
Alright i recently had a full performance rebuild on my transmission and it worked great the first 2 months i had it but now with it getting cold {30-50*F} the first couple of times it tries to shift into 4th gear it will shift in and out 3 or 4 times before it stays. So i brought it back and the guy who built it and he says its a sensor on the motor not the tranny. What you guys think? Any body have this problem before? Sorry For Being So long! THANKS
Old Sep 22, 2011 | 08:07 PM
mysterync's Avatar
Default Re: New transmisson has a problem?
Tps sensor, that's your problem for sure, set it to .98-1.02 volts. We install quite a few bell crank bushings which also "tighten" the movement up a bit. A good way to get a baseline is to adjust the bell crank to approx 124mm to the back of the bracket where the throttle linkage goes through
Guess I should throw in that if the starting voltages are within range and you gain voltage correctly that it could be a ground. You may find it required to adjust the throttle valve cable if throttle linkage is adjusted.
Old Sep 22, 2011 | 08:20 PM
STDiesel59's Avatar
Wow thanks for the quick reply! How would a person go about setting his tps himself? If you got any pictures that would greatly help.
Old Sep 22, 2011 | 08:25 PM
mysterync's Avatar
There are tons of threads and such with photos maybe someone will post. I don't have anything on my phone or I would help. I notch the sensor just a touch, adjust the linkage correctly and then it requires minimal adjustments.
One note is that while your doing it is a good time to replace any worn linkage, springs, and the bushings. It really reduces pedal effort and makes the truck more comfortable to drive. Also reduces chance of a hung throttle pedal
Old Sep 22, 2011 | 08:31 PM
STDiesel59's Avatar
Alright THANKS for all your help! I'll have to do some diggin.
Old Sep 25, 2011 | 02:49 PM
dennhop's Avatar
If it ends up not being the TPS sensor, there's a diode on the alternator that goes bad that cures this issue. Goerend sells a resistor, that taps into a line going to your PCM, that cures this problem. I installed it when I upgraded my tranny, and haven't had a single issue with it since then.
Old Sep 25, 2011 | 11:47 PM
STDiesel59's Avatar
Hey thanks for the info but i looked at the goerend website and i couldnt find the resistor that you were talking about. How did you find it? Thanks Again!!
Old Sep 26, 2011 | 11:24 AM
dennhop's Avatar
Is call them directly....the guy who did my install knew about it and ordered it for me. he's a dealer for goerend so he knew exactly what to do.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
flyers.nhl
Oct 31, 2014 04:33 AM
signoremint
13
Oct 21, 2014 07:21 PM
