Steering linkage worm gear
Old Sep 22, 2011 | 06:50 PM
madcreekfarm's Avatar
Default Steering linkage worm gear
I have an '06 F350. do those have a worm gear inside the steering linkage box? (i dont know exactly what that box is called but i know what i'm looking at when i see it) can it be tightened to take out play or slop?
Old Sep 24, 2011 | 10:20 PM
PowerstrokeTech87's Avatar
yes you can tighten it i believe your going to need to remove the CAC tube to get to it, that or the left hand inner fender well. DONT GO CRAZY with them! if you turn it a 1/8th turn its usually enough.
I assume your steering wheel is going left to right or feels "lose" id suggest checking the tie rods and drag link and if the steering wheel seems to have a mind of its own when your going down the road, turn the wheel all the way to the locks left to right and hold it at the locks see if it jumps to the opposite direction. thats an indication of something in your hydroboost system and are tricky without gauges to diagnose, pumps are easy to replace on these, 3 or 4 10mm bolts and keep the wheel straight youll be able to dig it out from the bottom just have to pull the pulley off and press it onto the new one.
Old Sep 27, 2011 | 05:01 PM
hey thanks man! the tie rod ends and all the linkage stuff underneath the front end that you can see is all ok. i belive its that worm gear but didnt know if it had an adjustment or not. i'm gonna have my mechanic check it out when i take it in. i'l tell them not to tighten the nut too tight.
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
BubbaDT55
Apr 12, 2015 10:47 PM
Beelzeboss
Feb 28, 2015 07:30 AM
sweetv8s10
Oct 7, 2014 09:47 PM
