p2146 code
Old Sep 22, 2011 | 10:12 AM
Big bubba's Avatar
Default p2146 code
07 dodge 2500 with p2146 code truck still runs and pulls great anyone know what the code means??
Old Sep 22, 2011 | 10:27 AM
NadirPoint's Avatar
Check the valve cover wiring harness. Probably that gasket connector. Could be a bad injector, but unlikely since it's running good.
Old Oct 12, 2011 | 10:05 PM
coalrollin06's Avatar
the P2146 code is Fuel injector group A Supply voltage Circ/Open... have you had your valve cover off? injector work? set your valves? im almost positive group A is the front 3injectors check the plug its self clean with contact cleaner. and put A small amount of dielectric grease in the connector> clear the codes and see if that works. if not pull the valvecover and check all injector connections and wiring clearance from the rocker bridges...
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
