Another Tranny question
Old Sep 21, 2011 | 12:10 PM
papa_4runner's Avatar
Default Another Tranny question
I had my Trans rebuilt twice now. When I install it after first rebuild it would not pull its self, the shop came and tow my truck and pulled it and rebuilt it again for free, now it seams to be shifting to fast as well slipping when going into overdrive.
My question is they are telling me that the Throttle Valve Cable is out of adjustment along with the TPS is needing adjusting, I check the TPS its setting at 1. Volt right where it should be. Will a TVC cause it to shift fast and slip while going into overdrive?
Old Sep 21, 2011 | 12:45 PM
white93's Avatar
A mis-adjusted cable will cause it to shift too fast. All the tps does is tells the ecm when to shift into od. It sounds like they messed up something inside.
Old Sep 21, 2011 | 01:00 PM
Thats what i thought, Thats why i posted on here to see if i was just being pissy about it
Lifted93cummins
May 31, 2015 02:16 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
wilki
Feb 12, 2015 09:04 AM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
Ol' RED!
Dec 11, 2014 10:00 AM
