what transfercase do i need?
Old Sep 21, 2011 | 12:28 AM
alexbland's Avatar
Default what transfercase do i need?
well i got my 4wd frame and all the parts needed for 4wd swap, now i just need to figure out my tranny issue. im thinking getting a new tail housing for my 47re, but i dont know what transfercase i will need. thanks!
Old Sep 21, 2011 | 11:10 AM
94 12valve's Avatar
241dld is what came stock in the truck, a 241 dhd is all you will need for a street truck
Old Sep 22, 2011 | 12:31 AM
alexbland's Avatar
Thanks a bunch!
is there anyway to mate the t-case out of a nv4500 truck to the 47re? i read online that the nv4500 has the 241 dhd behind it. so what will i need to run it with the 47re? and how do i ID the t-case? want to make sure its the right one
Old Sep 22, 2011 | 01:04 PM
94 12valve's Avatar
there is a stamped tag on the case telling you what it is, not all nv4500's had the 241 dhd behind it. make one from an auto fit a stick all you need is a input swap
Old Sep 23, 2011 | 12:24 AM
alexbland's Avatar
alright ill have to take a look tomorrow, i way laying under the truck for a while, any idea on what size bolt that is to remove the t-case off the tranny?
and im making it from a stick into a auto btw
is there anyone who sells a 241DHD input shaft 23 Spline
Old Sep 23, 2011 | 11:09 AM
94 12valve's Avatar
the case is held on by 6 14mm bolts, the shifter is also a 14 mm bolt, 4 16 mm bolts hold the front driveshaft on, after that all thats left is the speedo and breather tube.
For the input a dealer can get them, some online stores, or you can look for a used one.
Old Sep 23, 2011 | 09:51 PM
alexbland's Avatar
good news, its a 241DHD now i just need to order up a OD unit for my auto and a new input for the t-case and ill be ready to swap it all over
Old Sep 24, 2011 | 10:35 PM
alexbland's Avatar
so what is this wide/narrow bearing im reading, cant seem to find info about it..
RedChevy44
Apr 21, 2015 05:47 AM
