full cut delivery valves
Old Sep 20, 2011 | 07:02 PM
Powersmokin#3's Avatar
Default full cut delivery valves
1997 2500 Cummins mods 402 injectors timing advanced 17* star nute crank #4 fuel plate all the way up waste gate isn't tied close but it's screwed up I have.a new super b for it it now has a fass150 on it with 1/2 inch and built auto . when its in gear when i tap the pedal then let of it dies for some reason some body told me i need to get full cut DVs on it because the truck is not gettin enough fuel is that the problem need help
Old Sep 20, 2011 | 07:12 PM
daveO's Avatar
Sounds to me like your idle might be set too low. Should be 750-800 in drive with the a/c on for autos, or in neutral with the a/c on for manuals.
Old Sep 20, 2011 | 08:45 PM
turbo2332's Avatar
you do not need more fuel. expecially full cuts on a DD. DaveO is'nt steering you wrong maybe check the fuel filter but i would bet its a low idle.
Old Oct 5, 2011 | 08:26 AM
i adjusted the idle and i fixed it. but it still pops and cracks when its cold what could that be ?
Old Oct 5, 2011 | 10:19 PM
turbo2332's Avatar
any white smoke?
Old Oct 6, 2011 | 07:47 PM
monster12valve's Avatar
overflow valve?
Old Oct 12, 2011 | 07:28 AM
no white smoke it just hazes a little
Old Oct 12, 2011 | 07:46 AM
turbo2332's Avatar
your big injectors
Old Oct 12, 2011 | 10:08 AM
Farmboy 2.0's Avatar
Im with turbo2332. Anytime you run big injectors you will haze and cold smoke at a idle. Also whats pressures the injectors are set to pop at will have something to do with how they will haze too.
Sep 24, 2015 08:50 AM
Hutch58
Mar 21, 2015 12:13 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
Feb 18, 2015 01:00 PM
mrweasel
Oct 25, 2014 05:47 AM
