Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
Transmission Problem
Old Sep 19, 2011 | 03:47 PM
red dually's Avatar
Default Transmission Problem
I have a 2005 duramax with an allison transmission at take off or after letting off of the throttle and reapplying the throtlle I have alittle play in the transmission. Does anyone have any suggestions what it might be or know a good transmission shop for allisons in the Winchester, VA area or around there.
Old Sep 19, 2011 | 08:42 PM
2500HeavyDuty's Avatar
how many miles are on the truck, how is the fluid level and when was the last time you swapped the filters
Old Sep 19, 2011 | 08:56 PM
red dually's Avatar
The truck has around 84,000 and the fluid level is good but it has ben awhile since I changed the filter.
Old Sep 19, 2011 | 09:16 PM
BriteWhiteRam's Avatar
I change the filter with every oil change
Sounds like you might have some shift flare or a sloppy tq converter
Old Sep 20, 2011 | 03:45 PM
there is also an internal filter, sometimes it can wiggle around causing a small vacum leak on accel and decel
Old Sep 25, 2011 | 08:28 PM
red dually's Avatar
Brite White Ram is there a way to tell for sure that is is the tq converter and if it is the converter what is the best way to fix it replace it?
Old Sep 26, 2011 | 05:07 PM
a good scan tool can can do that for you. some one with a tech 2, snapon scan tool , or efi live.
Old Sep 27, 2011 | 10:27 AM
red dually's Avatar
2500 Heavy Duty my truck isnt showint any trouble codes so if there isnt any codes showing how or what will the scanner pick up.
Old Sep 27, 2011 | 11:58 AM
i mean to measure tcc slip to see if the torque convertor is your problem. but i doubt it
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
