Missing All The Time
Old Jan 8, 2008 | 05:31 PM
sawmillman's Avatar
Default Missing All The Time
Here we go a friend of mine is having a problem his 7.3 it has a miss?pulled the injectors no change.broke all the lines loose 1 at a time no change it seems to be a miss on no particular cylinder but a miss no fuel leak or air that I can tell it's driving me nuts.
Old Jan 8, 2008 | 05:43 PM
LOGANSTANFORTH's Avatar
so you did change all the injectors??? is it blue smoking bad??? could be bad rings or a burnt valve......
Old Jan 8, 2008 | 05:47 PM
sawmillman's Avatar
had the injectors checked no change have to ask about the smoking.
Old Jan 8, 2008 | 06:09 PM
Blue01F250's Avatar
Duramax Virgin
Yah, ask about any smoking, codes, oil leaks, etc...
Old Jan 8, 2008 | 10:09 PM
CODES!!!!! WE DONT NEED NO STINKIN CODES!!!!!!
not a whole lotta codes id say on a mechanically injected 7.3........
Old Jan 14, 2008 | 05:56 PM
Cowboy_Customs's Avatar
, nope no codes.
So when u cracked the injector lines there wasent a cylinder that made no difference at all? (u know, u crack a line on a good firing cylinder it misses worse, then u crack a line on the bad one it makes no change in idle)
I would be suspisious of a bad IP if all 8 are in fact firing. U said u had the injectors tested, pop tested at a diesel shop im assuming? did u have them reset to factory specs?
I chased an air leak for over a year before i found it, my truck would loose prime after a few hours of setting. How does it start, after a night of setting?? How much fuel is in it? does it do it both full and at 1/8th tank??
doublehbar
13
Aug 9, 2015 12:35 AM
1969olds
9
Apr 18, 2015 02:59 PM
Mar 19, 2015 08:10 AM
Nov 11, 2014 04:10 PM
Stick_Welder
9
Oct 24, 2014 04:10 AM
