Tie Rod end parts
Old Mar 30, 2007 | 03:45 PM
Nuttymopar's Avatar
Default Tie Rod end parts
Seems like my Tie Rod end (pass side) that goes from the Pitman Arm down to the Knuckle is a little loose. I don't feel it at all in the steering but I hear some loud rattle when hitting bumps and that is the only thing I can wiggle that almost sounds like that rattle.
Lift tire off ground and check up/down play & side/side play and it seems ok. But I can take and twist long shaft (tie rod) about 1/4" to 1/2" so it must be that which makes the rattle noise.
Checked shocks and couldn't move them at all so I don't think they are broken.
Local parts store say they can't get any parts for the Dodge Ram. Haven't checked with Dealer just yet but rather find it from some other source if possible. Maybe less $$ also.
63k on the truck.
Driver's side only has the typical Outer Tire Rod end (short piece). This thing goes the complete length from side to side and has tie rod at one end, then up about 6", a hole to have another piece bolt onto it, then it contiues all the way to the Pitman Arm.
Any suggestions would be great.
Old Mar 30, 2007 | 04:01 PM
Whit's Avatar
Site Mascot
Dan the gear man is the dude to get these kinna parts from
http://www.quad4x4.com/
Old Apr 10, 2007 | 12:04 PM
Nuttymopar's Avatar
I did give Dan a call and unfortunately, he isn't suppling any front end parts for my year Dodge just yet.
I did get a price from Dealer and only $125 so that isn't bad. I expected higher.
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
carid
Towing and Hauling
Oct 27, 2014 10:46 AM
Sculpturesylvan
Oct 18, 2014 10:40 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
